HP laser jet 1018 printing problem
My printer is about a year old and has been working very well since I bought it. Suddenly it started printing with thick black solid lines horizontally across the page at 3 inch increments. I read your description and you suggest this may be a dirty or damaged roller. What do I do about it?
thank you
On the the left of the paper being printed appears dark patches of ink that makes tha print-out look unpresentable. please assist
  • Anonymous Apr 02, 2009
    I have large black lines across the paper about 3-4 inches apart.
    Sergeant:
  • 366 Answers
Service is required (or a new laser you can now by at very low price)
Posted on Jan 30, 2009
Sounds like you have a problem with a damaged roller (see here: http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?docname=c00653645&lc=en&cc=gb#N1474 )
You will need to buy a new print cartridge
Posted on Jul 08, 2009
I have a black line on the leftside of paper when printing, with HP 1018 LASERJET PRINTER HOW DO I FIX
Posted on Jun 19, 2009
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
http://support.apple.com/kb/DL907
After downloading and install the update, please try the steps given above.
Mar 02, 2015 | HP LaserJet 1018 Printer
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
My hp laser jet 1018 is not printing
Please tell me a few more details or symbols so I can provide you solid solution.
Thanks
Mar 10, 2011 | HP LaserJet 1018 Printer
Having a 'spooling' problem with my HP Laser jet 1018 printer Therefore, my printer will not print anything!
In run window type services.msc and the go to print spooler option just stop and restart the service.
Nov 25, 2009 | HP LaserJet 1018 Printer
Why won't the website www.iambored.co.za load but everything else loads just fine?
Laser Jet 1018 when print fade color out
Hi my name is Robinson from Ethiopia,Addis abeba my printer is laser jet 1018 i need to ask I am buy another cartilage new one and then install in my pc affter install the cartilage toner i see this things
1.when i print fade color out but the cartilage toner is new what is this problem i am guse may be paper quality or weather selection i am ask this one when some other place change the printer print pure with out fade may be guse more u tell me plz if u can now
Thank u!
Jun 25, 2009 | HP LaserJet 1018 Printer
My HP laserjet 1018 doesn't work
first of all remove the power cable and rmove the usb connection or  parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
Jan 23, 2009 | HP Hewlett Packard LaserJet 1018 Printer
Hp laser Jet 1018
While printing A/4 size a bold doted line appear on the rigt side of the paper from top to bottom
Apr 17, 2008 | HP LaserJet 1018 Printer
Hp laser jet 1018 printer
hmmm..have you tried cleaning and re calibrating the heads?
Feb 29, 2008 | HP LaserJet 1018 Printer
HP laserjet 1018 service
Have you installed the new drivers for your HP?
Personally, on all HP Printers, I use only HP products, mainly Jetdirect Print Servers, but you might try creating a TCP Port Printer (via your Printer Install Wizard) and use that. You only need to know the IPAddress of the DLink and the Drivers for the HP Printer.
Dec 04, 2007 | D-Link DP 311U (DP-311U) Print Server
Hp 1610 and 1018
Are you printing from MS Word? What software package are you using? Each printer is different and some require software settings.
Jun 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
1,109 people viewed this question
k24674
jasbo
jasbo
