Question about Panasonic PT-44LCX65 Television
Green tint to bright spots on screen
I have a PT-44LCX65 I have replaced the bulb and now the tv is turning everything that is really bright to a green color. When in cinema mode and settings are dark it doesn't really do it, but if you put really bright you see green everywhere. I was wondering if there is any kind of solution for this? Thank you for your help
  • dbacksfan61 Feb 23, 2009
    Green spot on left side of screen. I have called Panasonic to see what their response it
    Novelist:
  • 184 Answers
Try to observe the problem when there is a white screen or predominantly white screen. If the screen is green or yellow where it should be white, its most likely a problem with one or more of the small LCD panels in the TV's light engine.
Its an expensive problem to fix. The light engine most likely will have to be replaced. Check with Panasonic customer relations for possible assistance.
michtech
Posted on Feb 13, 2009
Over past couple of months the tv has gotten 2 red spots in the lower right hand corner of screen about an inch in diameter, and recently a green spot in center top third of screen that is about 2 inches...
Unfortunately your light engine(also know as optic block) may need to be replaced. If your tv is out of warranty, it will probably cost around $1000 to fix. There is a slim possibility that the optics lens could have dust on it and a tech could clean it for much less than that. This is a very common problem in any dlp tv and they are all expensive to fix. I've replaced several of them at our shop, but about half of the customers won't have the tv fixed and will get a new one. Good luck!
Jul 30, 2010 | Panasonic PT-44LCX65 Television
Green blue and red spots across screen. I changed the bulb a few months ago.
You need to contact a serviceman. Your light engine needs replaced. Panasonic requires prior tech authorization for parts order fulfillment such as this. PN: TZSC03045 It will be costly, roughly $800 with $250 core charge. Labor and trip fees are another thing altogether. I hope this helps.
Mar 21, 2010 | Panasonic PT-44LCX65 Television
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Red, green and pink on the TV
Possibly a magnet was is the reason.Can you Degauss from the menu>>?
Jun 03, 2008 | Panasonic PT-44LCX65 Television
TV Image not bright enough
leagreen
I'm not sure if my answer will help much, but it is free. My experieence with this site is that without paying for premium service, you won't get much help.
I had a similar problem with a different model Panasonic projection set.I got no answer on this site, but I did from an outside repairman.
Turn your color all the way down. If it looks black and white it is probably not a bulb problem. If you see a tint (blue, green, red) over the screen, it probably is a weak bulb.
The entire bottom front of my model was held on by velco and could be pulled off.
Behind this was a removable black panel. Behind this were adjustment screws for the three bulbs. This will probably only help temporarily if the bulbs continue to weaken, but it might buy you some time as the replacement bulbs are quite expensive. Good Luck
Oct 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-44LCX65 Television Logo
372 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
