Question about APC Back UPS 650 (APWBK650MC) UPS System
Does not start
When i plug my UPS it does not response no currency flow. would you please solve my problem.
Regards.
Rao Kaleem
  • 24 Answers
Rao, there is an on/off button located somewhere on the exterior, they are usually flush with the case and push into the interior. A small led should light when turned on.
Hope this helps.
Posted on Jan 30, 2009
APC UPS is totely deat. No respone on back battery or main Please tell me detail thank
You have to take apart the UPS. Inside you will find a battery. On the battery you will find the make and model of the battery. Buy a new battery install it. Plug in UPS and turn it on.
Sep 19, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
I hit the button to turn it on it will stay on for awhile and then it will start beeping really loudly an shut off
With your UPS turned off, unplug your PC and all other devices from the unit. Then turn the UPS on. If it still beeps and shuts off your UPS internal battery may need to be replaced or you have an internal UPS failure. Look for a red "battery alarm" light on the front of your UPS.
If the UPS does not shut down with all devices disconnected from it, Power off your monitor and look on the back of the monitor for a label which will tell you the amount of power it requires (probably 100 watts or less). Plug the monitor's AC power cord into your UPS and turn on your PC and monitor. With the UPS plugged into the AC line you are not using the internal battery and the UPS should remain on and your monitor should be working. If it shuts down you have an internal problem with the UPS.
Now unplug your UPS from the AC line (simulating a power failure) Your UPS is rated at 350 watts. Accordingly it should easily support the 100 watt load of your monitor. If the UPS continues to provide power to the monitor for 1 or 2 minutes down it's an indication that it's working properly and the COMBINED LOAD of your monitor. PC etc. when plugged into the UPS is exceeding the 350 watt capacity of the UPS. You will have to disconnect 1 or more devices from the UPS.
NOTE: Never plug a laser printer into an UPS.
If the UPS immeadiately shuts down after disconnecting it from the AC line with only the monitor plugged into it you have a bad battery.
If you found this information to be helpful to you please return to the FixYa website and rate me.
Regards,
Yavacotech
Dec 07, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
Trying to pay for an order in L.a & it won't work?
Last day I read this Question and wrote an article to solve this issue,
Now you can read and follow instructions to make easy and fast foreign currency conversions online.
YOu Can read my Presentation REGARDING CURRENCY CONVERSIONS.
Dont forget to give credit to the solution
Oct 22, 2010 | PayPal Accounts
Hi i m using powercom ups but whenever i make the connections my computer restarts againand again i dont know why???
Friend have you plug and switch the ups properly, If so then check that you have also plug your computer pin properly into a ups. If this is also right then there might been problem in a UPS charging or in ups. It might also be a system fault. Just check out the system fault by applying the direct connection to the socket. If this solve your problem then check out all the procedure of ups to work and if this does not solve problem repair ups or charge it properly. If the ups is also not charged then it also make a problem to start for sometime.
May 13, 2010 | Computers & Internet
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
Belkin F6C800UNVPL UPS does not auto start
u have problem with ur automatic utility....
contact ur dealer or go to any ups shop.....
they will fix it in a very cheap cost man....dont forget to tell me u r problem solved or not
best regards & best of luck
Oct 03, 2007 | Belkin (F6C800-UNV-PL) UPS System
APC Back UPS 650 (APWBK650MC) UPS System Logo
140 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
