Question about Creative Labs ZEN Vision:M Digital Media Player
Menu, Play/Pause, Quicklink, Back Buttons not working
I'd had my vision:m for nearly three months, when all of a sudden all the buttons but the scroller and power/hold slider spontaneously ceased functioning; if this has happened to anyone else, or if anyone knows any way to get it repaired (can't bear to part with it--it's really the best mp3 player for the price in my opinion and up until now has served me beautifully) that'd be awesome. Cheers, Daniel.
  • 102 Answers
This happened to me. The problem was the case was cracked and was permanently resting on the buttons inside the zen. I ended up buying a new one. Upgraded to the 60 gig model at that time.
Posted on Aug 02, 2007
SOURCE:
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
Tip
How To Reboot An iPod Touch
If Your iPod Isn't Frozen
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
If Your iPod Is Frozen
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
on Jul 12, 2010 | Audio Players & Recorders
I have a Swann security system day/night vision cameras and the night vision has gone out on 2 of them and the system is less than a year old? Can any one help. Can these be fixed?
Check the power supply (usually 12VDC) and its connections. Lack of power for to LED's will cause the night vision feature to cease to function.
Aug 26, 2013 | Swann Communications Home Security
My sons ipod touch hasnt been used for a couple of months & now it wont turn on or show any signs of charging. i have tried holding the on/off & home buttons without success, please help!
Restarting your device
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
  1. Press and hold the Sleep/Wake button until the Apple logo appears.
    Follow these steps to reset your device
    Note: Reset your device only if it is no longer responding and the steps above do not work.
  1. Press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Oct 07, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Sudio 17 spontaneously shuts off
Troubleshooting With PSA Diagnostics on a Laptop Computer
STEP: Run the Preboot System Assessment (PSA)
Additional Information
  1. Ensure that the computer is powered off.
  2. Press and hold <Fn> and press the power button to power the computer on.
  3. Release both buttons. The PSA diagnostics sequence begins.
  4. Make note of any PSA beep codes or PSA error codes
  5. check PSA error code on support.dell.com
Dec 09, 2009 | Dell Studio 17 Notebook
Apple Ipod Is disabled
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
Sep 15, 2009 | Apple iPod touch
Rebuilds Randomly
Do the following on the Vision:M and run a cleanup. First, enter into rescue mode by detaching the Zen Vision:M player from your PC , and making sure that the unit is off.
Then, Slide the power switch towards the power icon and hold the switch in the Power On position.
Next, Push the end of a straightened paper clip into the reset hole,and press gently and remove.
The recovery mode will come up, I would choose clean up, this will not erase anything.
Also, I make sure the player is off before you shake it, as you can damage the hard drive inside if it is on when you shake it.
Mar 17, 2009 | Creative Labs ZEN Vision:M Digital Media...
TomTom Go720 shuts off spontaneously
tomtom GO-720 will not power back on after leaving on top of refrig off for the past two days now?
May 17, 2008 | Tomtom GO 720 GPS Receiver
Non-responsive scroller
well you can try and take it apart and see if you can see anthing wrong with the buttons, or you can replace the front with a used one on ebay.
http://repair4player.org/disassembly_creative.html
Jan 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
26 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
