Question about Motorola T9580RS Two Way Radio
Two motorola T9580 radios were donated to my organisation late last year, but to date we are still not able to use them because no one understands its mode of operation, can you help me out?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The simplest way to start fresh is to reset the radio by removing the batteries for an extended period of time. Thereafter,charge for at least 4 hours, power them on and the trick is to make sure both radios' display are identical, big & small numbers. Press the PTT (on the left side) to transmit and adjust the volume control for receiving/audio level.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
    Sergeant:
  • 326 Answers
I wish I'd never gave food to the first stray cat. When I moved into here. I can't seem to get any help. What was I suposed to do? Maybe find help for food.?
I understand your problem that now you will have difficulty ridding yourself of - if you really want to.
Cats are much abused and neglected by ill-informed and ill-intentioned people.
If you wish to help cats in need in your area I suggest you contact a Cat Protection League for advice and maybe thinking about starting your own branch of this worthwhile charity.
You could register as a charity, pester the local press and radio stations and ask local stores for donations of food and approach animal welfare/protection organisations and veterinarians to obtain low cost or free help and advice.
Many stores will allow charities to place a bin and a suitable sign asking for food donations either next to the checkouts or at the store entrance.
Sep 14, 2017 | Cats
I have a CP200 that beeps twice at regular intervals, and seek to correct this. It transmits and all, but the beeping is irritating.Suggestions?
It really sounds like a low battery alert. Swap batteries and check the date codes. How long off the charger until you get the beeping? Lithium batteries do not last as long (lifetime) as the older types. Motorola uses 4 numbers, year followed by the week such as 1344 = 2013, 44th week. Chargers are just that and do not test a battery. If the problem persists I have something else, but it is not easy.
Feb 04, 2016 | Motorola CP200 Two Way Radio
Is it true that goodwill does not donate any monies to charity that it's just a name like any other company
This is partly true..........sort of.
Goodwill is a not-for-profit organisation which is set up to provide good, affordable clothing and other items for those who cannot pay retail prices for decent stuff.
The money they take in from that keeps the organisation going (they have to pay wages, utilities, insurances, leasing etc) and it also provides jobs, training, references etc for people who might otherwise not find employment.
So it is a charity of a sort, but a practical one, and is not scamming you who donate.
Sep 18, 2014 | Computers & Internet
When was my realistic ctr-66 tape recorder manufactured?
Here is a link to some support information from Radio Shack for your model:
http://support.radioshack.com/support_audio/8258.htm
The dates on the documents seem to indicate that mid to late-1994 was the manufacture date.
Sep 03, 2014 | Audio Players & Recorders
Mag One Radio - Static
If your BPR40 radios are all about the same age, it could be a sign of your batteries getting old and needing replaced. A bad or weak battery will cause the radio to exhibit static, and then eventually poor or no transmit. Check your battery date code first, it is a 3 digit number on the battery label, followed by a space and then usually a number 1. On the 3-digit code, the first number is the year, the next two the week of the year. 229 would be 2012 the 29th week. Replacement batteries should be available for around $35.
If you feel the battery is not the issue, you may have ONE radio which is causing the problem. Try using all your radios and testing by shutting off just one radio at a time. You may identify the culprit. Motorola offers a one year warranty on the BPR40, after the warranty is done, flat rate repair is typically available for $69.
Third possible cause is some type of interference in your area. If this is the case, your radios may need a PL code programmed into them, if you don't already have one. This will filter out unwanted noise or transmissions. Sidenote: If you've added any new computers or electronic office equipment recently, it may also interfere. Some foreign produced computers will lack the filters required in the USA to prevent interference with communications. Coiling excess cables can be helpful in stopping RF noise.
The second of static at the end of your transmission is called "white tail" and is common in all modern radios. There is a programming feature to eliminate most of the white tail noise, it is called reverse burst. Your radio dealer can reprogram your radios and add this to your radios, or future radios you buy. The trade-off with reverse burst is that you will loose the last of your spoken words if you do not hold your PTT an extra moment, as reverse burst actually transmits back or cuts off the end of a transmission to eliminate the noise. White tail is worse when mixing old model and new model radios together.
Best regards.
Jul 12, 2012 | Motorola Mag One BPR40 Two Way Radio
Re: MagOne by Motorola, BPR40 -- What button should I push and how many times to make a radio stop beeping repeatedly before I can communicate? Thanks!
None of the buttons will solve this issue.
A repeating low tone is heard when you press the PTT if your battery level is low. You may have a bad or poorly charged battery. It takes more energy to transmit than to receive, so the first place this shows up is when pressing the PTT. A quick way to check this is to swap batteries with a known good radio and see if the problem switches to the other radio.
Battery tips: Clean your battery contacts with a pencil eraser to remove the film caused by hand oil. Always charge your battery with the radio turned off. And be certain your charger is plugged into an outlet that is not connected to a light switch shutting off power. Batteries last approx. 2 years. Check your battery's date code to see its age. (3 or 4 digit number, first one-two numbers are the year, second two are the week of the year. example: 1132 would be 2011 the 32nd week)
If the above does not solve your problem, you should see your local Motorola dealer, or a nationwide repair center for more assistance. Current flat rate repair on this style unit is typically around $69.
FYI: Your buttons are likely top button = monitor/sticky monitor and the bottom button could be hi/low power, scan or one of several other features. Each button has a short and a long press option.
Best regards.
Aug 09, 2011 | Motorola Mag One BPR40 Two Way Radio
Where can I buy a new charger for a Motorola T7100 2 way radio?
There are two pieces, don't know if you need both:
Wall adapter
Drop-In Tray
This is the same charger as the Motorola XTN and CP100 radios. Your local Motorola dealer may be able to assist you, if you were to mention these models.
And seeing you are needing a charger, you might also check your rechargeable batteries age. The life expectancy of this style battery is 18-24 months. On the battery label you will find a 4 digit date code. The first two numbers are the year, the next two are the week of the year. Ex: 1107 would be 2011 the 7th week.
And as you are likely aware, this radio will also accommodate 4 AA batteries. (The AA batteries cannot be charged using the charger, only the Motorola rechargeable NiMH batteries are compatible with the charger.)
Here is a link to the user guide http://www.giantintl.com/ContentManage/manuals/Moto/T71xx.pdf
Best regards.
Feb 17, 2011 | Motorola T7100 2-Way Radio
I BUY 2 WAY RADIOS MOTOROLA XU2100 OFTEN BUT LATELY THEY GET BURNED WHEN THEY ARE CHARGIN AFTER THE CHARGE I TURN THEM ON THE DISPLAY SHOWS THE CHANNEL BUT THEN IT FADES AWAY AND GETS REAL HOT THEN IT...
1) Clean all your battery contacts with a pencil eraser. This includes the contacts on the charger (if a drop-in style), battery and the radio.
2) Check your battery date code. It is a 4 digit number on the white portion of your battery. The first two numbers are the year, followed by the week of the year. (Example: 0946 would be 2009 the 46th week.) Your battery pack should be less than 2 years old to work correctly.
3) Check to see you are using the correct charger. The XTN style charger should have a white label on the cord indicating it is for the XTN radio.
You most likely have batteries which are failing or shorted out. It would be advisable to remove them from the radio and replace them with new batteries. Continued charging of shorted/bad batteries will damage your radio.
Best regards.
Nov 10, 2009 | Motorola XU2100 (1 Channel) 2-Way Radio
Can't make the T5420 operate without the beeps!
I have not looked up the T5420 user guide, however, on most Motorola TalkAbouts you hold in the minus (-) button while turning the radio on. Post back if this doesn't work, and we'll find the manual for you.
Nov 17, 2008 | Motorola Talkabout T5420 (14 Channels)...
Battery volts check
With the battery fully charged, you can us a volt meter. Touching the wands to two separate battery contacts. (I believe it to be the outter two. But you will be able to tell from the reaction of your meter.) If it show you a negative number, simply reverse your wands.
On the CLS1410 and its sister the VL50, there is a battery indicator built into the radio. It will show you on the screen how much charge is in the batteries. Also, with this style of radio, you are using a Li-Ion battery, which will last you about 12-14 months before you need to replace it.
There is a date code on the white portion of the battery label. It is sometimes hard to discern. But if you look you'll see the year followed by the month and date. If the radio was fresh from Motorola when you bought it. The battery date should coincide with its true initial charge age.
Aug 14, 2008 | Motorola MT1000 Compatible 2 Way Radio...
Motorola T9580RS  Two Way Radio Logo
275 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
