Question about Uniden Cordless Phone
My friend ring me they here the rings but i fail to listen at my end
    Sergeant:
  • 326 Answers
For GE : There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE  GHz:
 1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Posted on Jan 30, 2009
How do I install new piston in a homelite XL2 auto chain saw
up from the bottom of the cylinder
make sure that the ends of the ring is at the locating pin in the ring groove
pull the conrod right up and put a set of vice grips on to hold it up position the barrel over the piston and hold the ring in with your fingers
gentle push the barrel over the piston and the taper at the cylinder base will hold the ring in as you continue to push the barrel down
if you have failed to correctly align the barrel on assembly then make sure that the piston is at the top of the stroke before turning the barrel around as the ring ends may catch in the ports of the bore and break the ring.
May 30, 2015 | Homelite Garden
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
Jan 16, 2014 | Lands Phones
Our phones only ring 4 rings before going to message bank. We have a telstra wall connection, and 3 panasonic KX-TG1840AL
You can change the number of times the phone rings before the unit answers calls.
You can select 2 to 7 rings, or “Auto”.
“Auto”: The unit answers after 2 rings when new messages have been recorded, and
after 5 rings when there are no new messages. If you call your phone from
outside to listen to new messages, you will know that there are no messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 Press OK.
Select Answer System, then press >(Right navigation button).
2 Select Settings, then press >.
3 Select Number of Rings, then press >.
4 Select the desired setting, then press >.
5 Press End button
725a0bb.jpg Thank you
Aug 10, 2010 | Cell Phones
I have a 2005 Kia Spectra ex. Had mechanic look at it twice. Had battery alternator and starter tested. All good. Check engine light is not on. Just had tune up trasmission fluid exchange done. The power...
The ringing noise could be from a bad alternator, a loose bolt, a loose pulley or gear or possibly a low fluid level in the power steering pump. Try listening for the noise when the engine is idling, then as you rev the motor from 1000 to 1800rpm and also while you are driving on the street and the highway. While the car is in park and running, crank the steering wheel right and/or left until it stops and hold it there to listen for noises from the power steering. The electronic gurgling noise and chattering noises could be failing bearings in one of the pulleys (tensioner, idler,etc. and/or possibly a water pump bearing. Here is a tip for diagnosis- Find 3/8 drive extension that is at least 12" to 18" long. Open the hood and start the car. Take one end of the extension and place it on the alternator body away from any electrical connections, pulleys, belts, etc. and put your ear against the other end and listen for chattering, ringing or any other odd noise. Then do the same to the p/s pump, a/c compressor, etc. BE SURE YOU SAFELY APPLY THIS TECHNIC AND IF YOU DON'T FEEL COMFORTABLE, TAKE IT TO A PROFESSIONAL. SAFETY FIRST.
May 10, 2010 | 2005 Kia Spectra
Delay in my mobile ringing time.
go to profile settings,,,
select ringing tipe: ringing,,,, not ascending,,,,
hope it will work,,,,,,,,
Jan 14, 2010 | Nokia N73 Cellular Phone
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My phone has no song at all
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Nov 19, 2008 | Nokia 1100
Nokia 6600 no new message received display
HI Qrasengan,
1) Open the menu, and go to profiles.
2) Enter the general option, and click on personalise.
3) after that, several option appears.
4) some of them are ringing tone, ringing type, ringing volume, message alert tone, vibrating alert, etc.
5) Go to message alert tone and change the tone u want to listen when message is received.
NOte :Only wav or midi formats are accepted as ringing tone. MP3s are not accepted as ringing tones in NOKIA 6600. U need to install a software "mp3 as ringing tone" or "mp2wmaogg.codec" to make mp3 as ringing tone.
If u want that software, send me feedback or reply.
And I will deliver u as email in ur email id.
Sajan(sajwhat_2003@yahoo.com)
May 03, 2008 | Nokia 6600
Ring tone problem
MP3 format file are for you to listen to.
.mid, .aac, and .amr file extentions are ring tones.
You can download ring tones from:
http://www.zedge.net/
Jan 07, 2008 | Nokia 5300 Grey Cellular Phone
No ring and no answering machine.
My phones work, but the answering machine does not play back. My friends say that the machine on their end leaves a message.
Dec 23, 2007 | Uniden TRU9280-2 Twin Cordless Phone
Uniden Cordless Phone Logo
60 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
