Question about Thermos Grill2Go Gas Grill 4656110
Thermos grill-to-go. I have a thermos grill-2-go barbecue. the base has collapsed because the plastic support for the grill mechanism has split.Ineed to find a parts supplier for this model. can you help?
Found thermos website which I was unable to do previously. Thank you.
Posted on Jan 31, 2009
Barbecue won't stay lit
make sure the propaine is not to low and the burner orafice is clean
Oct 13, 2014 | Char-Broil CharBroil Master Flame Gas...
Why do flames shoot out the venturi tubes and out the front of the bbq control panel after 1 minute of being trned on????
blocked burner , or split burner , gas lighting back to injectors wrong air mix, leak on control panel ,
Jun 10, 2010 | Char-Broil CharBroil Master Flame Gas...
Mice in our barbecue grill. What to do?
Is this a problem all the time or just in storage? If it is in storage make sure they have not place to climg on to get in. Also in storage you can put steel wool in the bottom openings and this should keep them out.
You can also put mouse poison around the base while in storage.
If it is a problem during normal use make sure they don't have anything close by that they are using to climb aboard.
Apr 17, 2010 | Grilling
Need pars for my grill
try all part grill.com then go to cooking grids thay got lots of size
Mar 25, 2010 | Barbeques Galore Cook-On 3-Burner on Steel...
New grille for a Meco Swinger II Smoker Grill charcoal barbecue
Try http://www.shop.allinone.co.uk/eCommerce/product.aspx?cat=193&prod=6229
Jonathan
Jun 14, 2009 | Meco 4400 Swinger II
Bunners do not get hot
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Thermos Grill2Go Gas Grill 4656110 Logo
995 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
jdthefixer
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
