Question about Panasonic KX-TG1033S Cordless Phone
Echo on kx-tg5933alm when talking
Panasonic 5.8 ghz. suddenly started echoing me when on a phone call
5 Suggested Answers
SOURCE: Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Posted on Mar 24, 2008
  • 49 Answers
SOURCE: My Philips SE 450 sounds
you may have to enable a feature called voice enhancing on your voice, the echo is sometimes caused by feedback from various sources. it should appear as a VE symbol when you have it turned on, this helped me greatly when I was going through the same prob, it also makes the phone reception sound better on both ends. you may have to call the phone company to check to see if they installed the lines right in the first place. Also if your phone has the ability to change channels you can keep switching channels until you find one that sounds better to you.
Posted on Nov 13, 2008
SOURCE: I have a uniden dect
Hi, I have a dect 2035 and began having the same problem. I don't know how the feedback came about but it was suddenly there today when I tried using the phone. After mucking around with one of the handsets I hit the speakerphone button and turned the volume all the way down, it only goes down to a preset minimum, I then turned speakerphone off again and turned the volume for regular handset mode all the way down too. The phone works beautifully again!
Posted on Feb 13, 2009
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
Posted on Feb 24, 2009
I have a echo in my iphone when talking
it is may be not your problem. Problem Belongs to whoom your are talking with. He/She may be useing loude speakers. Or it can be problem of your mobile Service provider. Upgrade your cellphone iOS.
Apr 06, 2014 | Apple iPhone 4S
The reciever on long distance calls complain of echo on their side I have a KX-TG4023
Echoes are created when you have a delay and has nothing to do with your local handset cordless or wired. It is the carrier that you are using that may be responsible for this problem. You need to contact your long distance carrier for this problem.
Mar 25, 2012 | Panasonic KX TG4023 Cordless Phone
Our new 6.0 Caller ID phones have an echo. Can you suggest a remedy? John Chalk johnchalk@hotmail.com
as per jonniewalker from one of his posts:
"it may be due to interference from electronics devices around you since its a cordless phone ,or your phone is not getting a complete connection, could be one cause,Please try these solutions when you experience echo sound :
- turn the volume down
- turn the "clarity booster" function on the phone
Follow these steps to turn on clarity booster
1) Press menu/del during talk time (while phone is in use).
2) Press ^/vol or vol/v to move the pointer to Clarity Boost, and then select Boost On and "B" appears on the display. To turn Off the Clarity Booster, repeat above step again. check the owners manual for a full description for your model of phone
*Please note: clarity booster turns off automatically at the end of each call.
- make sure the Echo Canceller Circuit (ECC) has been set properly
*The phone should have Echo Canceller Circuit (ECC) built in.
*This means the circuit will study the Voice Level & reduce/cut the echo automatically.
Follow these steps to set the ECC properly
1. Unplug the battery from the handset for a few seconds.
2. Re-plug the battery back into the handset.
3. Make a phone call & at the initial stage speak loudly into the mic. Please note: The ECC will learn at the initial stage only, so after these steps are followed, the ECC will start working properly.or
just a simple pwr cycle ( turning the phone off) can give you a fresh registratoin, this can improve the quality of the call. hope this helps pls do let me know"
Feb 11, 2010 | Panasonic (KX-TG1032S) Phone
Echo while talking to some other phones
U see echoing isnt d problm f the phone... It`s the pbm of d service providers (yr network)....dnt worry they usually get repaired when the correspondn frequencies are altered.....
Apr 12, 2009 | Vtech Cordless 6041 Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-T7736 cuts out until cord is moved around
change cords to see if that works. Trouble shoot from there if it doesn't.
Apr 02, 2017 | Panasonic KX-T7736 Corded Phone (KXT7736)
Echo while talking on phone
I have a panasonic cordless 5.8ghz I hear an echo when I talk to someone . Can you please tell me how to get rid of it
Jul 07, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Very loud volume when turning on phone
Put it on Silent mode before you turn it off.
Feb 14, 2008 | Panasonic KX-TG6074B Phone
Multiple Telephone System Compatibility Issues
I most cases it should not matter that you have different phones to 1 phone line. You should make sure that all the phones are running off the main feed box for your property and not off each other. Check that all the wires are connected in each port and that the phone line running between the phone itself and the feed box does not exceed 50 feet because this can cause the phone to echo or not work at all.
Aug 11, 2006 | Telemania 027367 Spiderman Animated Phone
Panasonic KX-TG1033S Cordless Phone Logo
100 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
