Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Transcend jet flash showing write protected message
My jet flash drive is not formating and if i try to copy in that drive or try to delete it showing only one message"The disk is write-protected" Remove the write protection, and let me tell you it don't have any kind of lock it's
Model No is jf v30/2gb Transcend.
  • 11 Answers
Hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
May 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Jsph just asked: how do i unlock my file which i filed in my USB were write protected? and I don't remember where did i get or copy the protected file. can i reformat the whole USB unit of 8G? and delete...
Before formatting you can try an option of dowmloading "Jet flash recovery' tool from transcend website and recover the files.
Please come back and rate my solution if it turns to be helpful for you. Thnx
Mar 22, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have Transcend JF V30 2GB pendrive i m unable to format
go to transcend website and download Jet Flash Recovery Tool and format ur pendrive...... :)
Jul 19, 2009 | Transcend (589307) Media
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Hi ,i having 1GB of flash drive of Transcend company.for some unknown reason that showing "write protected ,disable it to use" message is coming.i tried several ways but not succeeded.how to disable that...
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Jun 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Write protected
write protected i am not able to copy nor delete files from my 4gb transcend memory card
Apr 17, 2009 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
I am having Jetflash v10 16 gb model 'Transcend' USB Flash Drive.
Dear Friend,
My Jetflash also writeprotected, there's no any solution for this in internet but I could solve this problem,
what you can do is, make your write protected drive "shared", that means go to my computer---> then rigtclick on flash drive---> click sharing & security---> check both "share this folder on network" & "allow users to change my files" ,apply setting then you'll be able to format your drive.
I could do it,
let others to know about this solution. Because I also suffered from this problem.
Amila--> +971559473812
asfonseka@yahoo.com
Feb 26, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
I have 4 gb transcend pen drive which shows write protection. How to remove write protection.
This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
Jan 20, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
765 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
