Question about HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
Print spooler everytime i need to restart the print spooler when i add a printer to a terminal on a network, why so? can u fix it?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
** Spooler Problem fixed **
I had the same Problem before and now I have it solved help of this follwoing article please click below and follow their mentioned steps and get your problem fixed.
Click here to open solved Solution for this problem Spooler not working (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
Posted on Mar 08, 2013
  • 258 Answers
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
To restart the spooler :-
click start --> run
type net spooler start click ok
or
click start --> run --> services.msc --> click ok
scroll down to print spooler --> right click on it and select start
Posted on Feb 04, 2009
I cannot print my documents, everytime I click the printer "print spooler is not running". I already restart my printer as well as my computer. And I also tried to reinstall my printer but it doesn
Click Start.
Type services.msc in the start search box and press enter.
Right click on print spooler and click on properties.
Check if the startup type is automatic. If it is not then change it to automatic.
Check if the service status is stopped.
If yes then click on the start button.
Try to add a printer and print a test page.
If you need any technical help on printer then you can reach at here
Jan 25, 2013 | Office Equipment & Supplies
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
Cant get it from offline to print
You did not clear that the printer is connected in wireless or Usb. However, below are the steps for both.
USB.
Please click on Start on the computer----Control Panel----Printers or Printers and Faxes or Devices and Printers.
Please right click on C6180 printer icon and click on use printer on line.
This will fix the issue, still persists, follow the below steps.
Click on Start- and in the search box type "services.msc" and hit enter.
Here, do we see an option print spooler?
Just stop that print spooler
and then restart that spooler.
WIRELESS.
Press the Setup button (c01461502.gif ) on the front of the printer.
Press the Down Arrow button (c00718778.gif ) to highlight Network , and then press OK .
Press the Down Arrow button (c00718778.gif ) to highlight View Network Settings , and then press OK .
Press the Down Arrow button (c00718778.gif ) to highlight Print Network Configuration Page , and then press OK .
Please note down the ip address of the printer and then follow the below steps.
Right-click on the printer Photosmart C6180 series---- click " Properties" , and then click the Ports tab
Click Add Port .
Click TCP/IP port and put (ip address of the printer)
, and then click New Port . The Add Port wizard starts.
Click Next ,
Follow the on-screen instructions to finish adding the port.
Then try to print and the issue will be fixed.
this isuue occurs because of the power failure or thunder storms or if we turn the router OFF.
I would suggest you to never turn off the router.
If, however, you face the same issue with the printer, please follow the same steps and the issue will be fixed.
May 13, 2010 | HP Photosmart C6180 All-In-One InkJet...
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
Print problem from network
Try installing the drivers that came on the CD with the printer.
Do the following on the machine connected to the printer:
  • Uninstall all previous drivers from Add/Remove programs (if any exist)
  • Go to Printers in the control panel and from the File menu choose Server Properties
  • Select the current printer driver and hit the Remove button
  • Turn off and unplug the printer
  • Restart your machine
  • Install the drivers that came with the printer from the CD
    Note: Do not unplug the printer till asked by the installer
  • Try to print a test page from the same machine
On the client machines, do the following:
  • Delete the printer
  • Delete the printer driver from the Server Properties window as above
  • Use the Add Printer wizard to add the printer
  • It will automatically install the drivers on the client machine
If the driver could not be removed, try resetting the Printer Spooler service:
To do that
  • Open Control Panel -> Administrative Tasks -> Services
  • Find the Printer Spooler service
  • Right click and Stop
  • Right click and Start
Good luck :)
Oct 27, 2008 | HP LaserJet 1018 Printer
Everytime i try to print it says that the print spooler isnt working. can you help?
You need to start the Print spooler service, this is in the control panel, under administrative tools, under services - then find print spooler and either start it or restart it.
Robin
Sep 16, 2008 | Office Equipment & Supplies
Spooler sub system app??
The issue occurs because of a corrupted printer driver installed and because of the Vista OS that keeps updating.
-Open up c:\windows\system32\spool\PRINTERS
-Delete the contents of the directory (not the directory).
-Restart the print spool service. (service.msc)
Jul 08, 2008 | Datacard SP55 Printer
Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
May 02, 2008 | WYSE Winterm S30 Network Terminal
DP-2330 on Vista
To start your spool service type spoolsv.exe in the run box.
Apr 10, 2008 | Panasonic Workio DP-2330 Printer
HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
