Question about HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
Print spooler problem when i add a printer - HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
  • 258 Answers
This is usually caused by invalid printer drivers left on a computer.
Go into "Printers and Faxes" delete all printers which no longer exist by right click --> delete
This should solve the problem
Posted on Feb 03, 2009
  • Peter Conway Feb 04, 2009
    To restart the spooler :-
    click start --> run
    type net spooler start click ok
    or
    click start --> run --> services.msc --> click ok
    scroll down to print spooler --> right click on it and select start
PRINT SPOOLER SERVICE IS NOT RUNNING MSG DISPLAY WHILE ADD PRINTER AND COULD NOT COMPLETE THE OPERATON
You need to go into services and turn on Print Spooler.
Start Run Type services.msc Click ok Scroll down to print spooler. Right click the entry Click restart.
Check that its startup type is set to automatic as well Right click the entry for print spooler Click Properties Select Automatic in the Startup type dropdown box. Click apply Click ok.
Aug 09, 2011 | Canon LASER SHOT LBP-2900 Printer
Unable to add printer there is spooler problem
1. Click Start -> Run 2. Type services.msc 3. Services window appears, Scroll down and look for Print Spooler roadfox_3.jpg
4. Click on Print Spooler, Click on the Drop down box set it to Automatic
Jun 04, 2011 | HP DeskJet F380 All-In-One Printer
On command to print with my epson lx-300+, message reads, "No Printer". When searched on fax and printer and double-clicked "Add Printer", a message came out saying, "It can't...
Hi Basti here,
Try this...
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
May 23, 2011 | Epson LX-300 Matrix Printer
All of a sudden, I can't print on my HP LaserJet 1020 and I don't see it anymore on list of printers/devices. When tried to add printer, screen displays "Windows can't open Add Printers. The local...
Hi.
Here is the procedures
Go to START MENU
Choose RUN (For Windows XP) or Choose Commad prompt, right click and run as administrator ( Fow window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Jan 13, 2011 | HP LaserJet 1020 Printer
Actually my computer has a problem.everytime i want to print some documents is shows an error named spooler subsystem application error..i have canon LBP 2900B printer. plz help me out
Print spooler is no less than the main master of printing proceeding. Print spooler is a linking section between your PC and printing hardware. Print spooler is the only master of print province of your PC office. Print spooler can inkle nothing and encounter an artificial virus threat which will cease your printing operation and compel your print spooler down on the count. Sometimes to solve print spooler problem it is enouph to clear print spooler, but in most cases you won't get rid of it.
To get rid of it there is a tool named printer spooler fixer.
The link to get that is below.Just copy it and paste in your browser
http://www.printer-spooler.com/download/fix-wizard/PrinterSpoolerFixWizard3.exe?key=FixWizard
Jan 07, 2011 | Canon LASER SHOT LBP-2900 Printer
I'm getting the error message whenever I try to select a printer that ''Windows can't open add printer. The local print spooler service is not running. Please restart the spooler or restart the...
If u r using the XP operating system, follow the steps to restart the spooler :
1. Click Start and then click Run and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which is opened now.
3. Right click on it and select Start.
May 08, 2010 | Office Equipment & Supplies
I have no print spooler service on my computer with window vista
I have the same problem with Vista. So frustrating. Going to switch to Windows 7.
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
Print spooler
To prevent the spooler from stopping, which is usually caused by invalid printer drivers left on a computer.
click start --> run
or
Jan 30, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
The print spooler
-Click start
-Click Run
-Type "net start spooler"
(without the " of course)
Jun 25, 2008 | HP LaserJet 1320 Printer
HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
