Question about Proton MM2701VT 27" TV
My old analog quasar tv keeps turning off and minutes and sometimes hours later it turns back on. The only thing that helps is when I bang it on the side and only then does it come on in that instance. What could be the problem?
  • 4,234 Answers
This is a good indication that there are poor solder connections inside the set. If you can solder and are comfortable working inside the set where potentially dangerous high voltages exist even when unplugged, you can fix this yourself. Look at the main board and resolder any joints that appear grainy or have rings. That should resolve the problem. If not, see if there are any changes in the symptoms and update this.
Dan
Posted on Jan 30, 2009
How can I replace the outlet for the cables on the back of my quasar SP 3234E TV?
A "freezing" picture sounds like something other than your television. Do you have a cable box or satellite box attached? They fail sometimes and need to be replaced. (You have an analog TV and "freezing" is a digital problem.)
Jul 22, 2014 | Quasar Televison & Video
It shuts its self off picture is still great everything works great it just makes a loud pop and shuts its self off i can turn it back on after a few minutes sometimes it shuts off again minutes later and...
saw a similar problem w/a Samsung and eventually the Focus Transformer gave out w/a big electric pop sound and all power went out. So it's probably related to a problem with high voltage and Flyback issue. Hope that helps a little.
Oct 02, 2009 | Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
TV Picture Pops In and Out Toshiba Color TV CZ27V51
mine was doing the same thing. If i put pressure on the cable input from left or right it would fix this.
May 22, 2009 | Toshiba CZ27V51 27" TV
Analog Quasar tv keeps turning off.
The bang test is a good indication that there are poor solder connections inside the set. If you can solder and are comfortable working inside the set where potentially dangerous high voltages exist even when unplugged, you can fix this yourself. Look at the main board and resolder any joints that appear grainy or have rings. That should resolve the problem. If not, see if there are any changes in the symptoms and update this.
Dan
Jan 30, 2009 | Proton MM2701VT 27" TV
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Proton MM2701VT 27" TV Logo
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
