Question about Proton MM2701VT 27" TV
Analog Quasar tv keeps turning off.
My old analog quasar tv keeps turning off. It does this in very sporadic increments and sometimes when it's on it wont turn off. The only thing that helps this is when I bang the side of the tv. What could be the problem?
  • 4,234 Answers
The bang test is a good indication that there are poor solder connections inside the set. If you can solder and are comfortable working inside the set where potentially dangerous high voltages exist even when unplugged, you can fix this yourself. Look at the main board and resolder any joints that appear grainy or have rings. That should resolve the problem. If not, see if there are any changes in the symptoms and update this.
Dan
Posted on Jan 30, 2009
How can I replace the outlet for the cables on the back of my quasar SP 3234E TV?
A "freezing" picture sounds like something other than your television. Do you have a cable box or satellite box attached? They fail sometimes and need to be replaced. (You have an analog TV and "freezing" is a digital problem.)
Jul 22, 2014 | Quasar Televison & Video
Does have my quasar model sp 323 tv have an ATSC tuner? was made in 2001?
No,all tvs have CRTS(Tv Tube).Are analog tvs,don't have ATSC tuner inside.
Oct 18, 2010 | Quasar SP-3234 TV
Quasar 20yr old color tv sound but no picture, is it repairable
try adjust screen up, in you see horizontal line in bottom, the tv have the vertical ic with cold solder or bad.
Apr 20, 2010 | Quasar SP-2723 27" TV
My old analog quasar tv keeps turning off and minutes and sometimes hours later it turns back on. The only thing that helps is when I bang it on the side and only then does it come on in that instance....
This is a good indication that there are poor solder connections inside the set. If you can solder and are comfortable working inside the set where potentially dangerous high voltages exist even when unplugged, you can fix this yourself. Look at the main board and resolder any joints that appear grainy or have rings. That should resolve the problem. If not, see if there are any changes in the symptoms and update this.
Dan
Jan 30, 2009 | Proton MM2701VT 27" TV
Is our Quasar TV (SP2723) a digital or analog television?
That's an analog TV and would need a converter box for the new digital broadcasting.
Nov 28, 2008 | Quasar SP-2723 27" TV
HD tv changes
The changes that you mention will only effect you if you use either rabbit ears or a rooftop antenna. The over-air broadcast signals are being changed from analog to digital. If you have cable or satelite service, there will be no change.
Dan
Nov 13, 2008 | Quasar SP-2723 27" TV
Quasar TV
Wow! This is an old message!
If you haven't tossed your set out yet, the problem you have (or had) was a failing vertical deflection circuit. It is (or was) not a terribly expensive repair and if you have replaced it with a plasma or LCD flat panel set, I hope you didn't dump your Quasar since most of the flat panel sets don't last past year 2. Any of these sets have serious problems and I would spring for an extended warranty any any of them; they are TERRIBLE. If you have parked your Quasar in the garage, look for a surviving TV repair and have it fixed.  Some of the parts used in that set will be increasingly hard to find so don't put it off too long. Also, if you do repair it, get a converter box for it too; it will not receive digital TV signals without it and they are coming in Feb. '09
HDTV info & coupons
Just spend a few minutes at this site and do some searching on plasmas (worst) and LCD (still plenty bad).
Jun 27, 2008 | Quasar SP-2725 27" TV
Digital
From what I see under amazon.com, it does not have a digital tuner.
But the February 2009 turn off is a deadline for over the air only.
When cable companies turn off their analog signals is a different matter. Some may soon, some may wait until 2012.
The gov't coupon program is only good for converters that handle the over the air digital ATSC signals, not cable's unencrypted digital QAM signals.
Jan 20, 2008 | Quasar SP-3235 32" TV
Pic problem
Quasar TV SP3232. Picture disappears but comes back by striking the TV . The sound keeps coming. Perhaps something is loose
Dec 23, 2007 | Quasar SP-3235 32" TV
Proton MM2701VT 27" TV Logo
62 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
