Question about Sony RCD-W500C 5-Disc CD Recorder
Not recording I'm having exactly the same problem that jhector reported in February 2007: I put in a disc, and it says "blank disc", then I press record as the manual says to do, but instead of "standing ready" as the manual predicts, the word "data" flashes briefly and it does not stand ready to do anything,
  • 112 Answers
You need to use an audio CDr, data or computer CDr's will not work in this machine.
Posted on Dec 09, 2007
Recorder will not read blanks or play disc
The device has failed, it happens all to often, this is the exact symptom, problem? the laser light is most likely burned out.
Jan 28, 2014 | Sony RCD-W500C 5-Disc CD Recorder
RCA model DCR8295 will not record my videos to DVDs. It says "no disc" when I press record, but there is a blank DVD in the drive
Have you formatted the disc?
It will be under the disc menu screen the format a disc option.
Does it also play a DVD disc? If it doesn't it might need a clean of the lens.
Mar 24, 2013 | Televison & Video
I want to use the optical input s a dac without going through the recorder
Put in a blank or unfinalized disc, press Record until Record Manual shows. This is similar to an old-school cassette deck being in Pause/Record mode. That should do it. The input signal will be present on the audio outputs (both digital and analog).
The manual isn't specific about how long you can remain in Record Manual mode without starting to record on the CD. My Pioneer has a Monitor function so I don't need to place a blank disc for this.
Jan 03, 2010 | Philips CDR870 CD Recorder
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
I can not get my CD recorder to record
You should use consumer cd's that are rather expensive. You probably tried to record a recordable cd-rom (a cheap computer disc). It's not possible to burn a pro-disc (computer disc) by using your Pioneer, and that's why you got that message on the screen. Refer to the user manual of your cd recorder and learn what sort of blank cd you should use.
Aug 05, 2007 | Pioneer PD-R555RW CD Recorder
Fisher cd-rw1000
ah..yes..mi friend, i was in that spot one time. one suggestion i have is-make sure the blank cd you are trying to record on is a "compact disc DIGITAL audio"...or try hitting the "input select" button.
Feb 08, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
116 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
