Question about Sony Ericsson Cyber-shot C902 Cellular Phone
USB device not recgonised by windows computer
I have already installed all the software and it worked properly before then the next time i tried it it told me " The USB device plugged in is not recgonised try plugging it in again" i did it a few times again still the same result.
    Genius:
  • 1,550 Answers
  • If the port is disabled you get this problem .
  • Go to Run and type "Devmgmt.msc" and press Enter.
  • Go to Universal Serial bus Controller. See if there are any red colored cross? If yes, right click and enable those USB Ports
  • Try with other ports .
Posted on Jan 30, 2009
Do not find my datatraveler when plug into computor?
By DataTraveler you mean a Kingston USB memory stick, correct?
Try plugging it into a different USB port.
If it doesn't, try plugging it into a different computer. Does it work there? If not, then your USB stick has probably failed.
If it works on another computer but not on the first, it probably means that the USB Storage driver software is not loading properly on the first computer. First, restart the computer. Does it work now?
If not, then you probably have to repair or reload the USB storage driver.
copied from Toms Hardware forum
"Go to start menu > Control Panel > Hardware and Sound > Device Manager.
If it's not already expanded, meaning showing the items listed under it, click the arrow next to "Disk drives" and see if it lists a Memory USB Device or something similar. Right click the Memory USB Device, or whatever your memory stick is called, and click "Update driver Software" then click Search Automatically for updated driver software. If that finds something then good, problem might be fixed, if it says "The best driver software for your device is already installed," close that window and right click the drive again and click uninstall then press OK. Then at the top of the window you'll see an icon that looks like a computer with a magnifying glass on it, if you hover over it it will say "Scan for hardware changes" click that and it'll reinstall the drivers."
Jun 25, 2014 | Computers & Internet
Dwa 140
Next, open device manager (Click Start Menu and type in "Device Manager", right click and run as administrator). Then find your device in the list, and uninstall it. Immediately, unplug the wireless USB from the computer. Now, restart your computer with the USB unplugged. Insert your driver disk and install the driver, when prompted plug the wireless USB back into the computer. Hope this helps.
Jul 01, 2013 | Computers & Internet
Sony nwz-b142 doesn't display in my computer. I already tried installing the device in the control panel and it says device works properly and yet it doesn't display in my computer
This advice could help you if your player works properly and the problem is in your pc only:
At first you should be sure that your USB cable can work.
Then let's see the PC.
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
gylacz
May 03, 2011 | Sony Walkman NWZ-B142 MP3 Player
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Im having a problem when connecting my creative zen to my computer my computer will not read it
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Once the device can be reached in MSC mode it should be ready to install new firmware on the player:
1. Backup data on the player to the computer when not on the PC already.
2. Reinstall / update firmware from computer to the player: after this the device will have all the maps for writing data and it can be approached in MTP mode again, using application software like Windows Media Player 11.
Online support page for guides, software and firmware for the Zen Mozaic, see:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic&bTopTwenty=1&VARSET=prodfaq:PRODFAQ_17897,VARSET=CategoryID:213
Need more help, just post a comment.
Nov 13, 2009 | Battery Technology Creative Technology ZEN...
My computer says found new hardware but when it tryies to install it says there was a problem does a search and finds nothing. So i cant update the firm ware,i already formated the zen but it did nothing...
Solution:
[Next]
[Next]
[Next]
[Finish]
Oct 07, 2009 | Creative Labs Creative Technology Zen MP3...
Usb ports
This can only mean on thing that the USB port on your computer is not properly working, what you can do here first is to run the setup CD for your motherboard so all the software including the driver for the USB port will be reinstall, if after that still not working the USB port of the computer is already bad...
May 27, 2009 | Computers & Internet
Installing camera assist software(webcam) on TOSHIBA
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready. 1. Click the Windows Start button.
2. Click Control Panel, System and Maintenance and then Device Manager.
3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver
4. Select Browse my computer for the driver software.
5. Select Let me pick from a list of device drivers on my computer.
6. Select USB Video Device from the list, and click Next.
7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close.
8. Restart Windows.
The webcam should now work properly.
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 28, 2008 | Toshiba Satellite A135-S4527 Notebook
Laptop toshiba a300-15m webcam driver
8. Restart Windows.
Jul 09, 2008 | Logitech 250 Headset
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
