Question about Dell Dimension E521 PC Desktop
Dell dimension issue: system is gone off all of sudden.. it looks like there is a problem with the add on card which consists 2 USB ports and microphone and headset speaker.... but this card is connected to the supply of power button
  • 3 more comments
  • pranavrshah Jan 30, 2009
    I have not remove the add on card .. its fixed in a very complex manner and is hard to remove. It is not USB speakers or headphones that are not working. We are talking about the full system which is not even booting up. I have checked that fan is working, all connections are made properly. Even hard disk is working fine.
    Now there is one add card which I am talking about. this card had 4 lights blinking previously when system was ok. Now this card is also connected to the power button so i assume its for supply, etc. but now when i open the system there are few lights on the card but I can't see any lights from outside and even there is nothing appearing on the monitor of the screen.
    I have also checked fan, it is working properly, there is no head sink problem. Yes i have gone out of warranty but I dont understand like if there is a light blinking on motherboard as well.... i dont think there is any problem with supply but how can this card affect for the system to even start at least... and also the card is located in such a complex way that i can't even remove or disable it
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    On the back or bottom of your PC is a label called a Service Tag, it is around 7 characters long including letters and is clearly ID'd as the Service Tag.
    Without that we can't help you very much. It allows us to login to Dell and see all the parts installed on your system.
    Your Motherboard LED should be on in a steady state and not blinking unless you are possibly in Hibernation.
    I will need the service tag to then find your manual.
    Thanks, I'll be back tonight.
    Worldvet
  • cosmataz May 11, 2010
    Does your whole system shut down? Assuming it does, you have to unplug everything and turn off comp. Reconnect everything again, and start it up. If this doesn't work, and assuming you have a UPS that is working, check your fan that sits on your CPU. If this is getting hot due to the additional hardware, your CPU will definetly shut off without notice. You must make sure the fan is working properly at all times. CPU heats up very fast w/out fan.
  • Glenn Rogers
    Are these USB speakers and headphones?
    Have you removed the add on card and have the problem go away?
    I'll be away from my terminal for a day but reply anyway as another expert may reply in my absence .Otherwise, if you removed the card and the problem has resolved itself, leave it that way until I can get back with you.
    I assume you are out of warranty? And, please include the Dell Service Tag.
    Thanks,
    Worldvet
    Problem Solver:
  • 3 Answers
It seems likely that you have somehow dislodged/interupted the graphics card GUI, which enables windows to come on the screen. Without this, the system will not boot properly due to the fact that your CPU is looking for it and cannot find it. You may want to double check to see if that card is in properly. Also, did you download driver for the new card? If not the right driver, it won't work. Another thing to check could be the IRQ I/O addresses (go to device manager/advanced) If they are not assigned a number, they won't work either. You can always hit F1 (it may be different on your comp, try f8 or f12) after you hit power switch, to see if it will give you the boot info before your OS starts up. Of course, you will not be able to see it if you have no video. Try to listen to the comp when turning it on. How many beeps does it make? It should only make 1, if it is making more, or a long one, you can find out problem that way.
Posted on Jan 30, 2009
I have a 2003 Dell Dimension 4600 and the network adapter is testing fine. However I am unable to access broadband internet and email through a wired USB/Ethernet connection to external modem. Both the...
the hard wired connection to the modem could be a system configuration issue, the cable has gone bad, or the modem is having connectivity issues with the service.
if your optical drives are not working physically, then you can't really fix that. if they just arent responding properly or Windows cant detect that they are there, then you may need to reinstall the driver software for the drives. which can be found on the Dell website or the manufacturer of the optical drives.
yes you can set up a wireless connection with a USB adapter but the modem also needs to have wireless capability in order for you to create the connection.
there are external USB optical drives available. so you can purchase a usb connected CD/DVD drive or burner. they shouldnt be very expensive nowadays.
Apr 22, 2011 | Dell Dimension 4600 PC Desktop
Where is the usb port located on the Dell Dimension E-310 computer?
4 ports on back, 2 on the front, 1 usb header on the motherboard
http://support.dell.com/support/edocs/systems/dim3100/en/index.htm#printed_documentation
May 13, 2010 | Dell Dimension E310 PC Desktop
Ctrl keys dont work, bought new key board and have same problem, have windows XP
First rule out drivers
- remove the keyboard driver and instruct windows to reinstall the driver
Next check for hardware issues
1. Plug this keyboard into another PC to see if the same problem persists
2. If the problem does occur it is the keyboard (get a new one if that is the case)
3. If the problem does occur then it is not the keyboard it is the port that u are plugging it into.
IS IT USB?
4. If it is a USB Keyboard, plug it into another USB port
5. If the problem persists on all USB ports on the system board, then the problem is the USB ports only IFF the keyboard works fine on another system in other USB ports
Is it PS/2?
If it is not a USB keyboard and it is a PS/2 board, again, and it works fine on another PC, then you have a defective PS/2 port on the system board.
Solution
Get a PCI card with USB ports and install it. Plug ur keyboard into that.
Mar 14, 2010 | Dell Dimension E310 PC Desktop
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
Can I replace a USB port on a Dell E-310?
No, however if it is still under warranty Dell can replace the board. If its not under warranty you can buy a USB add-in card.
Nov 15, 2009 | Dell Dimension E310 PC Desktop
Where do I find the usb port on my dimension E520 Dell computer?
E520 has 2 usb ports on the front right where the card readers are. It also has 5 (Five) on the back right where your ethernet cable hooks in.
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Add wireless card
You can add one via a USB port like THESE
Or you can add one to an empty PCI slot on your motherboard if you have one available. Like This One
Mar 01, 2009 | Dell Dimension 4500 PC Desktop
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
USB Header
The only way is to purchase a USB Board to install in the PCI slot, but that would be overkill since you PC already has 4) 2.0 USB ports. I would exchange that internal reader for an external reader.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension E521 PC Desktop Logo
82 people viewed this question
Alun Cox
