Question about Aiwa CDC-X227 CD Player
Aiwa CDC-X227 - No power to unit
In the middle of the trip, the unit kicked off. I've replaced the fuse in the back of the unit, the fuse in the main fuse block - rechecked the connectors. I cannot get any power to the unit whatsoever. I've also tried the reset button on the unit. I've had the car for just under a year with no issues. Any insight or suggestions would be greatly appreciated.
  • 156 Answers
Keep in mind that there are always two fuses in any vehicle that provide power to the radio. One fuse is for switched power, one for constant power. Both fuses need to be good before the radio will work. Often one of the fuses, especially the constant power fuse, is shared with other electrical circuits and may not be labeled as a radio fuse. Check all the fuses in the vehicle, including any fuse box under the hood. See if any other electrical systems in the car aren't working, especially the dome light, cigarette lighter, door chime buzzer, or clock.
Posted on Jul 30, 2007
SOURCE:
I have a aiwa CDC x227 car stereo. Have it hooked up, had sound until I accidentally hit the face plate button. Since then I have no sound. Any suggestions on how to get the sound back?
hi, you may have caused an upset to the data flow from face to main pc board. try disconnecting the unit from the vehicle for a day, then reconnect it the next day. or find the reset procedure for your unit, it will either be a small micoswitch behind the face, or a sequence of holding down some switches to activate the reset function. if the problem persists then the unit mite have a cracked main pc board, a faulty face unit, or the mute function is continuously running. to solve these faults you will have to consult with a technician.
May 25, 2012 | Car Audio & Video
Wiring/instillation, i need a wiring diagram to connect to a 04 f150 truck.
Do you have wiring instructions for the stereo or do you also need those?
Feb 14, 2011 | Aiwa CDC-X227 CD Player
I just got the aiwa cdc-x227 and the mute is on.how do you unmute it?
check for a logo that shows a speaker with a cross(X) across. just switch this back. this is also available on the remote. You could normally find this on the top side so as to mute easily when in a traffic junction. Check if this button is jammed. Also check if the display shows a mute , if not the sound reduction could be a different issue related to the audio output. check if any speaker connections are short, or speakers connections touching the body. Chek on the wiring once again with a multimeter , for any shorting, correct positve voltage and good ground. hope this helps. Good day
Jul 07, 2010 | Aiwa CDC-X227 CD Player
AiWa stuck on mute - no sound from subs.
have you tried powering down unit and seeing what happens?
Dec 02, 2009 | Aiwa CDC-X227 CD Player
Get a E03 error on display when playing CDs
It is not reading the cd. The laser is dirty, out of alignment, or bad. If it is under warranty, contact Aiwa. If it is not, you should just replace it. Just to take the lid off, and find out what is wrong will cost you about $80 at most repair shops. For $120 you can buy a new am fm cd with Ipod control and USB port. Hope this helps.
Aug 17, 2009 | Aiwa CDC-X227 CD Player
I need a mauual for car stereo radio cdc-x227
Are you asking for Instruction Manual or Service Manual, please mention it.
Nov 28, 2008 | Aiwa CDC-X227 CD Player
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
AIWA CDC-x227 CDPlayer
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Dec 03, 2006 | Aiwa CDC-X227 CD Player
Aiwa CDC-X227 CD Player Logo
199 people viewed this question
Top Aiwa Car Audio & Video Experts
Kitte Ka'at
Level 1 Expert
Joaquim Martins
Mike Duncan
Mike Duncan
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
