Question about Intel DG31PR Motherboard
Hello i m having a problem with dg 35 ec usb driver
  • Daniel Florin
    Daniel Florin May 11, 2010
    more info mode/make
  • 3 Answers
I have experienced similar usb problems if an usb device is attached during the installation of the operating system. If you are using the front panel usb port of the casing, make sure that they are properly connected with the mother board . try the usb ports attached to your motherboard at the backside of your casing.
If the ports at the back are not working, follow these steps:
1. Remove all usb devices
2.Go to the device manager
3.Remove the usb related hardwares usually under universal serial bus controller.
4. Reboot.
Hope this works.
Thanks
Bashar
Posted on Jan 31, 2009
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
USB
Hello visit ecs elitegroup here:
http://www.ecs.com.tw/ECSWebSite/Downloads/Downloads_list.aspx?MenuID=61&LanID=0
And enter the mainboard number, in seach for the driver.
Try also windows update, you need at least service pack 1, for windows xp, to support the usb function.
Good luck
Jan 19, 2013 | EliteGroup Computers & Internet
Windows7 sabrent drivers
hello,
your hard drive should be recognized by win automatically when you plug in.
Aug 29, 2012 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
Cant' find driver for motherboard driver ecs p4m800-8237
Sound: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1764&areaid=2&LanID=0
USB: http://eu.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2168&areaid=2&LanID=0
May 15, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
I need to get a new external mic for it. Where
Hello if your unit has a 3.5 jack I recomen this two
http://www.tvps.com/Products/ECS-35-mm-Tie-Clip-Microphone---New__ECS-3-prd-5TCM.aspx orhttp://www.tvps.com/Products/ECS-35-mm-Conference-Microphone---New__ECS-3-prd-5CM.aspx
Dec 21, 2009 | GE 35383 Handheld Cassette Voice Recorder
ECS780G USB Problem
hiya
this sounds like a driver issue as it is not being recognised upon boot up try and download the lastest driver for this device
Rik
Jan 23, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
ECS A780GM-A USB Problem
i had a simular problem  turn off your computer  hit the power button and go to bios  make sure the dongle is plugged in  is the computer trying to load from the dongle  disable this item if it is  are you running a raid on this computer if not  select the ide option in bios  you should have three choises  RAID APHCI  IDE  choose IDE and then recheck  thats how i fixed my simular problem  i hope that helps
Intel DG31PR Motherboard Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
