Question about Maytag MBB1956GES Bottom Freezer Refrigerator
White 'dandruff like' flakes blowing from front & back of air con
Our air con is wall mounted split cycle. Even without it being turned on, it is 'leaking' white flaky substance from the back. When turned on, it blows this substance as well.
Hope you can help.
Regards Dale
  • 1 more comment
  • md_colebrook Feb 03, 2009
    No, not wet, definately dry like a white flaky dust.
    Thanks peyton
    Thanks Peyton. Will give the unit a good clean out. Sounds like good advice.
    Regards Dale
  • peyton thompson
    peyton thompson May 11, 2010
    is this substance wet? like frost?
  • 410 Answers
This stuff is mold and mildew that builds up in the blower and evaporator section of your unit the unit needs to be cleaned out i'm not familar with this particular brand so I cant tell you how to pull it apart but since it is a split system this means the freon lines will most likely have to be pulled loose. you may try removing the covers and vacuming the unit as well as you can and possibly blowing it out with compressed air. aside from that I would recomend alling a qualified service comapny. good luck peyton
Posted on Feb 03, 2009
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Best home remedy for Dandruff
no home remedy get head and shoulders , it is the best , does not work the first time but does work , I had it for a long time and this is the only thing I found to work ,
Apr 21, 2015 | Health & Beauty
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
I had dandruff after washing my hair with this shampoo. What is the problem?
might i give a suggestion my daughter has serious exema on her scalp and causes some dandruff flakes from time to time she is only 12 i have found a wonderful product for her at walmart which relieves the itch and the flaking its a neutrogena t-gel its sold at all walmarts and in northeast i can the bottle being like 12 bucks where now im in hawaii and the price is only 6 its about the only thing here that is that cheap dandruff is usually removed with an amount of coal tar 2.5% the walmart version is called equate therapeutic shampoo if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Feb 05, 2011 | L`Oreal L'Or?al Force Vector Force Vector...
What does a df error code stand for on a con-air heat cool split system wall mount
Friend!,
Please ensure with your model/brand and error code. To my knowledge and web search, I don't find tour model on market. Don't be angry, plz check once again and write back.
Dec 15, 2010 | LG LSC183VMA Split System Air Conditioner
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Good after noon i have a Starway Split Wall Mount Reverse Cycle Air Con. the problem i have is when i need to warm my house the air coming from the system is cold. even with the temp setting on the sun...
Examine the condenser. The condenser pushes the air and expels the warm air from the air condition to the house. Also check the fan heater on your system to see if it is functioning, because if it is not, it will circulate the heat from the unit to the house, in this case,it will need to be fixed. also check if the thermostat on the unit is regulating because if it is not regulating, you will not get the house to warm due to bad thermostat, check to ensure it is regulating, if not, replace it, it might be defected because that is the key to regulate the unit. so pay attention to it to see if it regulating the unit, if not, replace as advice.
Take care.
Jun 12, 2010 | Heating & Cooling
Not sure of settings
On the remote, press the mode button (might also be labelled master control) until a snow flake appears. Then set the temperature for 23 degrees. The speed of the fan can be changed by the fan button. All functions should cycle through so if you go too far, just keep pressing the button until you get back to the desired setting.
Jan 18, 2010 | LG Heating & Cooling
Require specifications for an Emailair split level air con model CWS 034A
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Oct 31, 2009 | Heating & Cooling
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Maytag MBB1956GES Bottom Freezer Refrigerator Logo
197 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
