Question about Rowenta Powerglide DE011 Iron with Auto Shut-off
Rowenta SM700 (Listed 40N5 or S)
Had the iron for almost 4 years and now it does not warm up.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most models, some common faults are:
  • faulty AC plug, cord and/or the line feed to th iron itself;
  • thermostatic/temperature control and/or the auto-shutoff;
  • open heating element.
  • A continuity or multi tester (VOM/DVM) would be required to check the above components. This wold be a matter of checking if there is continuity from the plug to the cord to the feed-in to the switch to the element.
Good luck and thank you for using FixYa.
Posted on Jan 30, 2009
    President:
  • 2,559 Answers
The thermostat (auto shutoff sensor is bad)It can be repaired at most electronic repair stores,but may be cheaper just to buy a new one.
Please rate this a fixya
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
No green light
Just buy a new iron.
May 13, 2015 | Irons
Rowenta SM 700 iron won't turn on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 11, 2009 | Rowenta SM700 Iron with Auto Shut-off
Rowenta SM700
YOU HAVE TO READ THE SOLUTIONS
Jan 30, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta Powerglide DE011 Iron with Auto Shut-off Logo
67 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
