Question about Oracle 10g Database Standard (ODBSEONUPP0)
What is an sdf file and how it creates from which application.
    President:
  • 2,559 Answers
.SDF File Extension (SQL Database File), the filef ormat for Microsoft SQL Server Compact databases.
Please rate this a fixya
Posted on Jan 30, 2009
What is .sdf file
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Sep 03, 2011 | Oracle 10g Database Standard (ODBSEONUPP0)
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
I HOW I EXPORT TALLY 7.2 DATA IN EXCEL FORMAT
Step 1
Or
Step 2
Step 3
Nov 10, 2010 | Tally T2245 Matrix Printer
Whst is the difference between .mdf,.ldf & .sdf?
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Dec 03, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
What is a .sdf file? How to generate a .sdf file using ms access?
http://filext.com/file-extension/SDF , you will find here info about a .sdf, it has more meanings
Oct 28, 2009 | Oracle 10g Database Standard (ODBSEONUPP0)
Wanna create shortcut for application
right click on the application you want and click send shot cut to my desktop
Sep 27, 2009 | Computers & Internet
Add a excel format in tally
Sir,
What to Export ?
Tally has a facility to export its data to other applications like spreadsheets, word processing software and other database software. Export of data is provided mainly for summaries and statement reports like Trial Balance, Stock Summary, etc. You can export it to another company using Tally that will import it directly.
How to Export?
Thanks
Good Luck
Aug 14, 2009 | Adaptec Computers & Internet
I am trying to connect to a SQL Server 2005 DB from Visual Studio
You must create an ODBC connection to your SQL database in the Windows Control Panel. Than you can call your ODBC connection via Visual Studio 2005. You can also create a DSN in Visual Studio 2005 and reference in that way. You will not be able to connect to an MDF but instead you have to connect to the SQL Server Service. Of course the username you use to connect must have access that will be created on the SQL server.
Apr 13, 2009 | Microsoft SQL Server 2005 Standard Edition
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and Visual Studio 2005 to build, test, deploy, and manage applications for users. Databases of this type can be accessed directly as a datasource, e.g., from Visual Studio 2005, or from SQL Server Management Studio. As such, they can be passed around with programs or projects, although they are mainly used for embedded applications. The file includes all necessary code points to access the data, and so does not require an instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
Oct 17, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Oracle 10g Database Standard (ODBSEONUPP0) Logo
262 people viewed this question
Top Oracle Computers & Internet Experts
CNewton2
CNewton2
Level 1 Expert
cwradio73
Bonded Repair
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
