Question about S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0 HDD ENCLOSURE CASE SILVER Drive Case
I have problem with sigmatel S3 handset when i switch on the camera it shows camera module is not ready like this
Praveen:
jst press *### & that switchs to factory mode than u c 5 options press the 5th option,then selct the 2n option gekewei & press ok as 2 times & everything will b allright!!!!!!!!!!!!!
Posted on Sep 15, 2009
External 3.5 inch IDE hdd encloser connected via USB is showing "device is not ready" when try to initialise it in the disk manager
Check the jumper settings of the IDE hard drive you have in the enclosure for compatibility in your setup. (Choices are Master, Slave and Cable Select).
Feb 06, 2014 | Computers & Internet
How to remove the write protected micro sd card?
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Dec 06, 2010 | Kingston 1 GB microSD Card with USB 20...
Computer doesn't find back up drive
try to an another pc, if your backup works, then you need to uninstall some drivers from your pc
Mar 03, 2010 | S3 iMicro IMB5EE-B 3.5inch eSATA & USB 2.0...
I installed a Seagate Barracuda 1.5TB Hard Drive as a removable hard drive on a Gateway LX6200 running Windows 7. It says the software installed and it is ready to use, but when I go to ''computer'' to see...
Go to the contro panel > Administrative Tools > computer management > Look in the left side pane and click on "disc management". Your drives will appear here including ones that may not be "initialized". If you see a drive that has no letter, maybe just a number like drive 03, this drive is not initialized and needs to be done if it is to be recognized by the computer. With the disc management window open, look where it lists the disc. Your main hard drive should be disc 0. If this external is connected via a usb, this disc maybe listed as disc 01 or just 1. Right below the name it will say that the disc is offline. If this is the case, right click in that gray area where the name is and click on "initialize". A series of windows will open asking you to click ok on what kind of drive it is to be used for. Just go with the choice that is already given and click ok. The drive will then be initialized and it will then be ready for formatting. Simply right click on the area next to the name that says unallocated and select format, choose ntfs file system and the size of the partition if you want to make several partitions, this is the time. then choose quick format. The drive will the make the partitions and give the partitions drive letters. Your drive is all set up.
If it comes up and says that "the device is not ready" when you try to initialize it, then the drive or the interface is bad.
Dec 26, 2009 | Seagate Barracuda ST31500341AS 1.5TB 32MB...
Explorer does not see the hard drive
sounds like drivers are not installing correctly or you need software installed to see the drive go to there website or give me the make of drive
Aug 20, 2009 | Computers & Internet
I have sigmatel s3 set,the problem is when i connect usb 2 pc nothing happens & their is no web browser in this set plz answer
Jun 12, 2009 | S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0...
USB is not able to connect to pc quickly
hi,when you connect it it asks for 1.mass starage 2. com port u have to choose mass storage then start transfering data from pc to mobile.............if its not detecting then problem with ur handset connection port(hardware prob).....
Jan 23, 2009 | S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0...
I HAVE ASIGMATEL S3 MOBILE I CANOT USE GPRS
how GPRS activete in my sigmatel mobile s3 pls guide me
Jan 16, 2009 | S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0...
SIGMATEL S3 MOBILE
I have a SIGMATEL S3 mobile. When I connect it to computer. Mobile is Charging but USB not recognised. How can I connect with my P.C. Help me . If there is any driver software or not ?
Nov 17, 2008 | S3 MTG EC-3511-S 3.5 INCH SATA TO USB 2.0...
Computers & Internet Logo
64 people viewed this question
Top S3 Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David Payne
David Payne
Are you a S3 Computer and Internet Expert? Answer questions, earn points and help others
