I am unable to remove the agitator from my Kelvinator K605 washin
I have removed what appears to be the retaining bolt but the agitator remains fixed in place
Please help
Agitated
  • woodspen Feb 01, 2009
    The solutions worked fine, thanks to who ever it was who posted it.
    In found there was insufficient room under the agitator to use a loop of rope but a piece of fiberglass parcel tape worked just fine. It also needed a tap with a rubber hammer to encourage it to let go.All fine now.
    Thanks again
    Woodspen
    Sergeant:
  • 326 Answers
 Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
he agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
read more about the agitator removal in the next comment.
Posted on Jan 30, 2009
  • moniter Jan 30, 2009
    Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
    Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
    If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
    Click here to order replacement parts.
    for more detailed instructructions click the linkhttp://home.howstuffworks.com/how-to-rep...
Trouble removing valve cover on the right side (passengers side) of the engine on a 1996 mark viii. Help
  1. Remove engine appearance cover retaining bolt and nuts.Remove engine appearance cover from vehicle.
  1. Disconnect engine control sensor wiring at intake air temperature sensor (IAT sensor) connector and crankcase ventilation tube from air cleaner outlet tube.
  2. Completely loosen air cleaner outlet tube to throttle body bolt (captured bolt).
  3. Loosen clamp on air cleaner outlet tube to engine air cleaner (ACL) and disconnect air cleaner outlet tube.
  4. Remove remaining bolt from support bracket clamp on RH valve cover to air cleaner outlet tube.
  5. Remove air cleaner outlet tube and engine intake air resonator.
  1. Remove two retaining nuts from engine air cleaner outlet tube bracket to valve cover and remove engine air cleaner outlet tube bracket.
  2. Remove four nuts retaining RH ignition wire cover and remove cover.
  3. Disconnect ignition wires from spark plugs with a gentle twist! pull motion on the spark plug boot. Remove spark plugs.
CAUTION: Do not pull on the ignition wire as it may separate from the connector in the boot.
  1. Remove bolts and studs retaining RH valve cover to cylinder head.
  2. Remove valve cover.
Sep 28, 2017 | Cars & Trucks
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
Kenmore washer agitates on spin cycle
Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
Thank you
Jan 23, 2010 | Washing Machines
I think my daugther's retainer is stuck under the agitator. How can I get it off to check?
If this is a Maytag Atlantis model washer, just follow these steps to remove the agitator:
1. Remove the center post cap and softener dispenser by pulling it off.
2. Locate the agitator bolt under the center post cap and loosen.
3. With the agitator bolt removed, lift up on the agitator by grabbing the bottom flange.
If the model number is incorrect, please post back with your correct information. I hope this helps you.
Nov 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
How do you remove the agitator?
All depends on the make, some have a bolt in the center under the cap/dispenser and Maytag had a retainer bolt in the side. Once the bolts are out a strap placed under the agitator makes removal easier and saves your fingers.
Eric
Aug 26, 2009 | Amana Washing Machines
Removing cab from 2003 ford ranger. three of the biscuits turn.
been there done that. just cut them off and get new ones. by the time you go thru the trouble it wont be worth the headaches. I have had to drill holes in the floor of a chevy with a hole saw because the body mounts were broke off. just not worth the time to try and save a few bucks on bolts. get new ones. hope this helps. mike
Jun 16, 2009 | 2003 Ford Ranger Regular Cab
Agitator
These are called agitator ratchet's and are located beneath the plastic retainer cover which is held in place by a 3/8" bolt. Remove bolt from agitator and remove. You may need to use a flat screwdriver to depress 3 glued tabs within this plastic retainer. From top use hammer lightly tap with screw driver until all 3 are free. Turn agitator over ratchet's are accessible. Order agitator ratchets. Thank you
May 29, 2009 | Whirlpool LSR6334LQ Top Load Washer
Kenmore Dual Action Top Load washing machine bolt won't catch
that sounds like a bad lid switch. No need to go into the agitator.
Jun 22, 2008 | Washing Machines
Im tryin to fix my washermachine
To check the agitator, grab hold of is and see if there is any movement, to remove , first remove the softener cap (14) by pulling, look inside, secure or remove the securing bolt (4) using a long socket extension, once undone remove the top agitator (1) then the bottom agitator (15), check the condition of the splines, refit in reverse order.
Mar 18, 2008 | Maytag PAV2300 Top Load Washer
Washing machine
Sounds like the agitator securing bolt is missing and what you see is the remaining washer (" a plate with a hole in"), if the bolt is missing the agitator should simply lift up to remove, the securing bolt is a 10mm x 40mm should do the job, you will need a 17mm socket and long extension to refit the securing bolt.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
1,221 people viewed this question
Top Washing Machines Experts
