Question about Husqvarna Lily 540 and 550
O cannot quite get my tension right.
I borrowed this machine from a friend of mine.He does not have the manual for it.I am trying to get the tension just right.Cam you help?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Adjust the dial below upper tension unit (where you thread the top thread) to increase/decrease tension as needed. You might also want to check for loose threads or fluff in the tension area keeping the discs from closing correctly. Good luck.
Posted on Feb 13, 2010
My bobbin thread breaks too much. How do I fix it.
Be sure you are using the correct bobbin for your machine. Even though it appears to fit the bobbin case, if it is the wrong bobbin, it could cause major headaches.
Try a different bobbin. Try different thread.
Also check that the bobbin thread is wound smoothly and turning the correct direction in the bobbin case. Make sure the thread is threaded through the bobbin tension properly.
AVOID old and inexpensive, bargain bin thread!
There could be a nick or burr somewhere that is catching the bobbin thread and breaking it.
Try loosening the bobbin tension a bit. It could be too tight, especially if the bobbin thread is pulling the upper thread down to the underside of the fabric.
There could also be something wrong with the bobbin case itself that may be resolved by trying a new bobbin case (or borrow one from a friend, etc.)
Dealing with Lower Thread Breaking Sewing
Bobbin Thread Breaking How to Loosen Bobbin Tension
Nov 10, 2016 | Sewing Machines
My sewing machine needle (very new one) keeps jamming every couple of turns of the needle - and the thread is very loose and loopy on the fabric. It makes a jarring noise
not quite sure how needle is jamming. I have had them break, had thread ball up underneath and caused needle to jam. Question is the needle in the right way, ie the flat side in as per manual, generally the flat side faces away from you. Sounds like your tension is not quite right if the thread is looping. Loops on bottom, bobbin tension, on top sewing machine tension
Dec 08, 2014 | Sewing Machines
Adjust thread tension
Looking at a pic of this model, there are two dials on it. One near the top, one much closer to the needle. I believe the tension dial is the one that's close to the needle.
I don't quite understand what the problem is with the stitches from your description, but first try the tension dial. Reset it to zero and then try each setting, one by one, to see what happens.
If stitches are still wrong, a few things always to try when there are stitch problems. Clean well around the bobbin case, remove all lint. Do this often anyway, it's not good to let lint build up.
Try a new needle and a new spool of thread. Rethread the machine, a few times if need be. Try a new bobbin too, or wind a new bobbin to try from a new spool.
Try to get a manual for this machine. If Brother no longer has manuals, there are many sites that sell manuals for many machines. A manual can be your best friend when there are problems.
Jul 06, 2014 | Brother LS-2125 Mechanical Sewing Machine
A friend asked me to thread her Janome 352 sewing machine without instruction book. The solution posted assumes that I know what all the parts are but although I have sewed for 30+ years I couldn't...
you can go to www.sewing.about.com and check out Debbie's sewing machines 101 guide. She has images, diagrams and general threading up.
or your friend can purchase a manual from here http://ifixmachines.com/vmchk/Janome-Model-352/Janome-352-Sewing-Machine-Manual/ilvm_fly1_blue.tpl.html
tally_girl_30.jpg looking at this image I would say "raise the pressure foot, take the thread from the spool holder at rear of the machine and take to the left and through the first thread guide (cant see one but there will be) then down the right side of the metal flat thing, through the guide at the bottom, then back up the other side of the metal thing and through the take up lever (turn fly wheel until this is tat its highest point to get access) then back downwards, through the thread eye near lower edge of machine head, then down to the needle bar thread guide and through the needle.
The tension device will be in that top area where the metal piece is and the horizontal white dial on left will be tension control dial.
I hope this helps you and your friend out, 4 thumbs up if so :-)
May 31, 2011 | Sewing Machines
Just borrowed a friends machine but no instructions for threading cotton from top to needle and how to put in spool.Have got thread on spool.Just need to sew a basic hem
You haven't said what mail and model machine this relates to.
You could try http://sewing.about.com/od/sewingmachineindex/tp/operatingasewingmachine.htm, there is lots of good general information there which might be of help, most machines have similar functionality, ie a bobbbin goes into a rotary hook and there will be a tension spring on that thread. Top thread will also need to go through tension device, usually discs in the threading path from spool to needle.
There is usually a stitch length and stitch width dial/knob/digital selection and a stitch selector for different utility stitches such as blind hem, overcasting etc. If you just want a straight stitch, then stitch length would be 2.5 or 2.7 maybe for a heavy fabric.
You need to put in the correct sized needle for the fabric you at sewing too, http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Important thing is threading up so that both threads are under tension, make sure the pressure foot is raised during threading so the top thread can go between the tension discs. The bobbin will either be drop in top loading in which case you need to click the thread into a tension spring on the side of the bobbin holder. Or front loading bobbin inside a removeable bobbin case which is mounted vertically. The bobbin case will also have a tension spring on it.
Also you could try You-tube - there is lots of videos there for different brands.
May 15, 2011 | Sewing Machines
Hi, my lower tension will not adjust no matter what I try. The top stitching is fine but the lower stitches are very loose. My machine is quite old but in good condition. It is a model 2201 EC1 Series. I...
Be sure to ALWAYS RAISE the presser foot when threading the top thread. This allows the thread to seat completely in the tension disk. The higher the number on the tension disk, the tighter the top tension. If the bobbin thread is laying on the surface of the fabric, try increasing the top tension.
Thread tension is basically a tug-of-war between the two threads. They should exert the same amount of pull against each other. Perfect tension is when both threads meet in the middle of the fabric.
Of course, since your machine is older and parts do wear, your machine may need an adjustment or even replacement of some parts, like the bobbin case. The tension spring on a bobbin case will wear over time and the top tension may lose some of its tension.
TIP: Be sure to treat your machine to some well-earned TLC--cleaning and oiling. Oil dries out over time and will begin to stick parts so they no longer move freely. Below is the method I've used to free seized machines. You'll be amazed at how nicely it runs and your machine will run for many more years!!!
Wheel on right side that controls the needle up and down is very tight...
Oh yeah, here's a manual:
https://www.manualslib.com/manual/1143961/Toyota-Rs2000-Sd-Series-Stf17.html?page=45
Nov 25, 2017 | Toyota STF17 Sewing Machine
I have an Elna Funstyler sewing machine and when i sew zig zag the bobbin thread shows up on top, have tried changing tension and doesn't help. Is there any way to oil this machine? Instruction manual say...
If your thread tension is OK and u have correctly threaded machine, I would check manual for first the right bobbin and put in machine right. I have have issues from badly wound bobbins too. If you have replaced correct needle and your fabric, thread and tension are good, I would check manual for the right bobbin tension. Wish I knew more to help......
Dec 15, 2010 | Sewing Machines
I borrowed a friend's serger (Europro 534 DX)for a
Try setting the differential feed to it's lowest setting.
Test with scraps of what you will actually be stitching.
Mar 01, 2010 | Euro-Pro 534DX Mechanical Sewing Machine
Sewing Machines Logo
209 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
