Question about Belling DB92 Dual Fuel (Electric and Gas) Kitchen Range
How to remove inner door of belling db92
I am unable to remove the inners doors of both ovens to clean them. Although they lift so far they hit on the stainless steel control panel. Can you suggest how I can remove them. Thank you
    Brigadier General:
  • 8,619 Answers
Hi!
You can try this link for the exploded view of your belling dual fuel kitchen range.
Thanks
Rylee
Posted on Jan 30, 2009
How do you clean the dirt/food "in between" the glass in the bottom oven door
Open the oven door. In the inside you will see a number of screws along the edge of the door. Unscrew them and you will find that you can lift/split the inner panel from the outer panel. If it sticks look for more screws at the side of the door to make sure that all the screws are removed. Lift the inner panel carefully an you will have access to the "inside" of the glass panel. Re assemble by reversing the procedure.
Mar 31, 2015 | Ovens
Separate door and glass from Ignis FXVM6 oven for cleaning
To separate the inner glass from the door. Unscrew the sixsided screws sitting in the middle of a back plastc box that retains the glass at the bottom of the inner glass on each side. Once the screws are out , remowe the small boxes and lift the lower part of the glass before pulling it towards you. There are four sticky pads that keep the glass in place, so make sure they stay in place when you remove the inner glass and clean the door. To refit, reverse the operation.
Sep 10, 2013 | Ovens
Hi, The inner glass on the door of my Belling 295 SS built in single oven has completely shattered after just preheating it (quite hot although!). I bought it in 2007 so it would be out of warranty. Can...
Hi.
You should not need to replace the complete door, just the door glass.
If you have not already done so, then I would suggest you contact the maker direct, they should be able to help you.
Try the web site.
WWW.BELLING.CO.UK.
Jan 11, 2011 | Ovens
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
How do i take the door off to clean it
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Feb 06, 2010 | Stoves 720EF Electric Double Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
How do I remove the inner glass sheet from my oven to clean it
Remove the oven door first. There are usually 2 release tabs to flip up at the door hinges. Lift off and set on a flat surface. Then remove screws to separate the inner and outer door panels. Remove more screws and brackets until you access the glass you want to get to.
Jun 21, 2008 | Kitchen Ranges
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Belling DB92 Dual Fuel (Electric and Gas) Kitchen Range Logo
354 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
