Question about Sony KP-51HW40 51" Rear Projection Television
Blue bow on screen no sound
Tv works ,but as soon as you turn off and back on you get a blue bow tie.after turing itoff and on nothing
    Novelist:
  • 184 Answers
The blue CRT (picture tube is bad) These TVs were a real problem. Picture tubes began failing in these sets within 2 years of use. Sony warranted some of these TVs for a short while but has since abandoned their customers so they could build defective LCD projectors which are now the subject of a class action lawsuit.
Kick it to the curb and start lookin' for a new one.
michtech
Posted on Feb 13, 2009
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
I have this same problem with the PT51HX41E but in the convergence menu the green and red are allowed to move. but the blue on the right side of the screen is not allowed to move and it looks like its...
My first guess would be a bad convergence amplifier - this is common, although usually all three of the amplifiers in the integrated circuit die at the same time, which throws off at least two colors and creates a "bow-tie" effect. I surmise you have half of a bow-tie in blue only.
If you could look at the blue output waveforms with an oscilloscope, you would see right away if this is the problem (flat-line instead of sawtooth wave). It is possible that both of the blue convergence amplifiers are working, but one output is not getting to the blue deflection yoke.
Don't mess with the convergence anymore until you get this taken care of. Changing the convergence now will only make it harder to get it back to where it should be once the circuit is fixed.
Sep 22, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Picture on the screen looks like a bow-tie red, green, and blue are seperated on screen
magnetized tubs, check if you have any speaker nerby tv. to correct image is a degauss function tv menu
Dec 22, 2009 | Zenith R57W46 57" Rear Projection...
Samsung 5415r problems
blue line indicates a major diod or capasitor got failed by replacing it we can rectify this problem... if we go to repair it then shop keeper will tell you that its picture tube got flashed........
Oct 03, 2009 | Samsung PCL5415R TV
Picture is blurry and is shaped like a bow tie on my tv
This is a convergence problem that you can fix if you can solder. Let me know if you wish to attempt the repair and I'll post additional details and instructions.
Dan
Oct 10, 2008 | Mitsubishi VS-55707 TV
My picture turned blue after i unplugged the tv
did you ever fix the problem?
my tv went blue screen also
needed to charge the lamp so did but now can't get the new lamp to work
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Nothing but a blue screen
Good day.
No fuse was blown in this case. It has something to do with the filter capacitor along the screen supply to your crt circuit.
Have it checked by the repairmen since the problem is internal.
chris
Mar 22, 2008 | RCA HD56W58 56" TV
Picture is suddenly "bowed" and the convergence is askewed at everypoint but center.
the problem is the EW cicuit of the deflection cicuit. this is a component level repair call a tech. the EW or East West correction is apart of the horizontal deflection. IC431 is the pin amp.
Feb 06, 2008 | Akai PT5598HD 55" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
