My pc accepts mp4 hardwear momentarily then rejects it
I have checked the mp4 including installation on two other pcs however my pc sometimes does not recognise and sometimes the mp4 appears on my computer page as a removeable disc but after a few moments it disconnects automatically. Can you help please?
    President:
  • 2,559 Answers
Turn the player off and while plugging in the usb cable hold down the power button until the computer says "new hardware found" and "drivers have been installed for your new device" "Your device is now ready to use" Now release the power button.
If this don't work,post back with player name and model
Please rate this a fixya
Posted on Jan 30, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Since the device works in 2 other computers, then the issue is with the USB device drivers of your PC. In Device Manager, verify that the USB is installed with no yellow marks. Additionally, you could uninstall all the USB Root Hubs and Universal Serial Bus Controllers. On reboot, the OS would auto-re-install the necessary drivers. Alternately, you can update the drivers of the USB from your motherboard manufacturer rather than a windrows update.
Good luck and thank you for using FixYa.
  • 13,433 Answers
A connection is possibly loose, seems like a hardware problem that would require service. Check the usb connector and its pins.
You have tried it on two other pcs? what was the result there did it work? If it worked on both fine, then the issue is on your computer and not on the mp4 most likely.
Please clarify.
My MP4 won't charge or turn on and the USB port isworking fine, my computer won't even recognise that the mp4 is connected
You can turn off the Mp4 for a while and re-install the system ,and then you can change if the port is fit the computer ,you can also used a transfer interface to connected the computer .
Dec 11, 2012 | Philips Gogear Vibe 8gb Mp3 Mp4 Video...
The software is not recognised by my computer and the DP605 is also not appearing in the CD Drive as it said it would in the User Guide????
Some PCs, will not recognise softwares. It depends on latest version and configuration. contact system vendor/hardware/software engineer. Try.
Mar 03, 2011 | Computers & Internet
Under a year ago I bought an inphase Aura 4Gb MP4 Player I had trouble with the first one that I had as it wouldnt turn on and it would appear that this replacement I was sent maybe having a similar...
Suggestion for charging: You can buy a power adapter with a USB connector in which to plug in your cable that doesn't require anything from your computer to supply the 5 volts for charging.
You probably had a second disk with the driver on it... software is often delivered in two pieces. Also you can try the manufacturer's site as they may have a free download and install.
Jul 01, 2010 | Computers & Internet
Pc does not recognise it
Install the drivers for ur player and then connect it
Apr 25, 2010 | PC Mall OPro P3866/256/30/NIC for...
Notebook compter not recognising my mp4 player
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
Feb 26, 2010 | Microsoft Windows XP Professional
Sony K610i Will not sync with my computer
Please ensure that all drivers are installed. Check in device manager.
Right click on my computer and select properties. Then select the hardware tab and device manager in that section. If any drivers are not installed properly they will appear with a yellow exclamation mark. Reinstall these.
If all drivers are installed correctly check the contacts on the phone as sometimes the tend to get dirty and block the signal. also check if cable is faulty.
May 25, 2009 | Sony Ericsson K610i Cellular Phone
USB IOGEAR not recognise
Most portable HDDs show up without drivers being required, so, assuming other drives or USB devices show up the general assumption is that either the circuit board in the enclosure has failed or the HDD has failed.
Assuming it doesn't work on other PCs and that other USB devices do, take the external drive to your local computer shop and ask to have the drive tested and moved into a new enclosure. If the drive is OK then the people at the computer store can simply transfer the drive into a new enclosure and it will work. If it fails testing you will likely need to send the drive to a Pro, I would recommend Armor-IT Data Recovery(listed in the FixYa directory).
You can swap the enclosures yourself if you have basic hand tools and are feeling handy but it might be nice to have the techs at the local shop test the drive.
If you need any further instructions add a comment on this post and included the make and model# of the failed external drive and I will offer further assistance.
Hope this Helps FixYa,
Chris
May 20, 2009 | IOGear 40GB USB2.0 40GB 4200rpm 480Mbps...
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
I need to know how to download music to a mp4 player.
all mp3 and MP4 players have a built in USB port for connecting it to your computer, connect a USB cable to your MP4 player and the other end of the able to your computer's available USB port, windows will recognise the drive and install it for you. all you need to do is to go to my COMPUTER and double click on your MP4 player drive to open the content of your drive
check to see that the drive is has foldes like MY MUSIC, you can use windows media player to sync music files in your library to your MP4 player.
Dec 13, 2008 | Classic Electronics MP6410 MP3 Player
52 people viewed this question
 Grubhead
Grubhead
