Question about Sony Cyber-Shot DSC-S60 Digital Camera
Time for new flash??
I am having issues with the flash for my DSC-S60. Anytime I use the flash the pics turn out to be extremely underexposed or extremely overexposed, resulting in pics that are basically black, or basically white. I have tested the flash with every single setting and exposure imagineable, I even tried longer downtimes between taking pics, but the flash still mucks up. Is this fixable? Or is this camera kaput for anything other than daylight pics? Thanks in advance for any help!
  • Anonymous Feb 13, 2008
    yes, i too am facing this probelm. The camera worked fine for almost 2 years, but its not giving good pictures now.
    Problem Solver:
  • 36 Answers
The camera's light sensor or metering system, for correct flash exposure is no longer working, that's why your shots is either black or white (overexposed or underexposed) the flash firing has loose its control because of the defective sensor, it now only depends on the charge current of the flash capacitor. If you'll wait longer time the charge is maximum picture result will be overexposed(white), and vice versa, less charge, dark result, have the flash assy replaced. Daylight no problem, it doesnt use the flash circuitry, thanks
Posted on Sep 14, 2007
SOURCE:
Over exposure
I had a problem with overexposed pics as well as horizontal lines. Try initializing you camera ( return to factory settings) by clicking menu and then scroll down until you see "Initialize". If that doesn't work, then do a power reset (This fixed my problem).
1. Remove battery from camera.
2. Hold power button for 60 seconds
3. Replace battery, and try taking pics.
If neither of these resets work, then you should try chatting with a Sony rep. You will your model number ( DSC-H70 ) https://www.docs.sony.com/startchat.asp
Sep 05, 2012 | Sony Cyber-Shot DSC-H70 Digital Camera
Using AA+ batteries camera shws pic sbt shuts off on camera mode
Nicad batteries only hold 1.2 volts.each...the older cameras need the alkaline which are 1.5 volts as that brings the voltage to 3 instead of 2.4
Nov 20, 2017 | Sony Cyber-Shot DSC-S60 Digital Camera
Flash overexposing
  • Page 22 talks about adjusting the flash level see the instruction manual - link below
  • Looking at the handbook - see other link below - Page 41, details how to adjust the flash level, for more or less output
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 07, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Wont turn on
I don't know if this will help, but try it. Install new batteries. You may have enough power to view the images, but not have enough power to operate everything. There are also microcomputers in the camera. You can also try removing batteries, WAIT 1 FULL MINUTE, then reinstall (making sure the polarity is correct). Hopefully either of these simple solutions help.
Nov 29, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
I lost my manual and would like to know how to clear all pics
in your menu go to the camera icon then go into format
it will ask you if your sure you want to format
choose the option yes and it deletes all previous pictures
Jun 14, 2008 | Sony Cyber-Shot DSC-S60 Digital Camera
Flash on Cyber-shot DSC-W50 not working properly
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and
Dec 27, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Hi, horizontal lines on still pics
are you getting overexposed pictures. check this by clicking outdoors.
Oct 11, 2006 | Sony Cyber-shot DSC-H5 Digital Camera
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Sony Cyber-Shot DSC-S60 Digital Camera Logo
119 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
