Question about Car Audio & Video
"low impedance" Years ago i had a rockford fosgate "punch 4040" 4 channel amp. The recommended minimum impedance was 4 ohms mono/2 ohms stereo. I had it wired up 2 ohms mono rear and 1.5 ohms stereo front and even once had all 4 channels bridged at 1.5 ohms mono/per side without ever having any problems! My question is this>>> Anyone out there have a rockford fosgate p200.2 or 400.2 running 1.5 ohms stereo? or 2 ohms mono? Any overheating problems? I would also like to know if anyone has a "hifonics txi-4008" ,"cadence txa-1502" or a "soundstream tra 340.2" that are running impedances below what the manufacturer recommends so i know what to expect if i try to do the same thing. Thanks........................
    Problem Solver:
  • 22 Answers
It is really hard on an amp to run it below recommendation or specs and most audio companies won't warranty if they catch wind. but i have not seen an amp last long or operate without cutting out when you do this.
Posted on Jan 31, 2009
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
What is the watts on my rockford punch 360
Punch 360 can be wired as Mono and Stereo. Actually it it a 2 channes stereo amp, wirable to Mono too. When wired as Mono, the output power will be 450Watts. When wired as stereo, the outputs will be 210Watts/Channel. OK.
Dec 18, 2011 | Rockford Fosgate Car Audio & Video
Amp shut off has power and grond and remot but only my p550 shut off fuses are ok and all other amps are wourking
how many subs are you running on this amp, and how many ohms are they. if the are bridged, try hooking up stereo and see if the problem still occurs. make sure your scrape off all the paint where the amp is grounded to the frame which should be less than a few feet. i'd also recommend running at least a 4ga wire for both your power and ground.
Jan 30, 2011 | Rockford Fosgate Punch P550.2 2-Channel...
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Wiring for 2 subs for max performance
This amp is rated at 500 watts into a 4 ohm load bridged mono or 250 watts x 2 into 2 ohm load stereo. Do not go below that impedance in either case. The amp was meant to dissipate a certain amount of power, driving it to hard will lead to damage. Your speakers look like they are dual voice coils @ 4 ohms each. To get the max power while still saving your subs would be to parallel the voice coils on each woofer then run them in stereo with your amp. Stereo 2 ohm is 250 watts per speaker.
Dec 14, 2009 | Rockford Fosgate Punch 501S Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    How to bridge a punch 3001 car amp
    You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
    Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
    I have a rockford fosgate p250.2 amp hooked up to two 12' subs but the amp is not powering on... instead the protect light is on and im not sure if its because its so cold outside... please help and thank...
    Remove the load from the amplifier (subs) and the RCAs
    If the light stays on, there are internal problems with the amplifier, and it needs to be serviced.
    If the amplifier works normally, attach the RCA's and power on again.
    If it remains on, connect one sub, and then the other.
    Your amplifier is a 2 channel amplifier rated at
    60 Watt - 4 Ohm - 2 channel(s)
    125 Watt - 2 Ohm - 2 channel(s)
    250 Watt - 4 Ohm - 1 channel(s)
    Your amplifier is not rated for a 2 ohm mono load.
    If you have Single voicecoil subs wired in parallel, you have a 2 ohm mono load - your amplifier will eventually fail.
    Jan 16, 2009 | Rockford Fosgate Punch P2502 Car Audio...
    Car Audio & Video Logo
    173 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
