Question about HP W2007 LCD Monitor
HP W 1907 v LCD Monitor after few seconds it goes dark
My HP W 1907 v LCD Monitor power is on after split seconds it goes dark. Whats the problemof this. I opend it already but only the rear case. How can I open the front lcd glass so that I can see inside the Main board.
  • Ryan Stiers
    Ryan Stiers May 11, 2010
    When the monitor goes dark does the power light on the monitor stay Blue (or Green) or does it change to Orange?
    Also I would not recommend you opening the Monitor at all. If you have had this monitor less than a year, you are still within the manufacturer's warranty. Call HP tech support line because if the monitor is faulty and you are in warranty they may send it in and repair it or replace it. If you do call HP, do not mention that you opened up the rear case, as this may void the warranty and they will not be able to help you.
SOURCE: HP vs19e flat panel monitor died
power supplybdown
Posted on Apr 04, 2008
Mark_Webber
  • 472 Answers
SOURCE: HP L1702 lcd monitor power on then goes off
There are 8 caps that need to be replaced on these monitors.
2x1000uf 16v
6x470uf 10v
It is an easy repair if you know how to do it. If not, then your local TV repair man can do it fairly cheaply and quickly.
Posted on Apr 08, 2008
SOURCE: hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Posted on Jul 10, 2008
SOURCE: How can I open the HP w1907 LCD Monitor
I have just opened an HP W1907. It does not open from the back like Dell!!! The black plastic bezel with the HP logo on the front must be removed.I pried mine lose and broke most of the plastic nibs that hold it in place. From examining the bezel, it appears the a thin hook should be slipped in between it and the light gray plastic then pry up the back of the black bezel. The nibs on the black plastic bezel are facing downward and you must somehow lift them up and over the matching locks on gray piece. If you pry on the black back piece, as in Dell, you will break off four post the have screws put in from the front.
I hope this helps.
NKN
Posted on Oct 19, 2008
SOURCE: My HP LCD comes on when I turn on the power,but for few seconds.
It is a capacitor 16V, 1000uF.
Posted on Feb 11, 2010
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor turns on for about a minute then screen fades to a half lit and then goes dark. if you turn it off even for a split second it comes back on and then repeats. This monitor has had less than 20 hours...
If it is left plugged into the wall, the power supply is always running 24/7 even the power switch is OFF.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 03, 2010 | Samsung SyncMaster 216BW Monitor
Monitor turns on then split second window displays and goes dark
You may need to change your desktop resolutions, they may be out of range for your monitor.
you may need to swap the monitor to perform the actions
Jun 21, 2009 | Acer AL2017 20" LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
HP W2007 LCD Monitor Logo
923 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
