Question about Philips HI-296 Iron
No audio is coming at all in my philips 29 inch Hi-fy tv.
On oneday morning when we switch on the TV, it was switched on with more volume, then we tried to reduce the volume, as it is taking time we switched off the TV. After that again we switched on the TV, TV has been switched on without any problem but without audio only video, could you please let us know the solution and the steps how to solve it.
  • 150 Answers
If you have a provider box it also has a volume control,manully turn your tv up and use your controller to turn the box up.
let me know
Posted on Jan 30, 2009
Philips iron keeps turnning off
We have the same problem here. The station only switches off after some time, but the iron itself keeps being switched on. So you manually have to switch on the station many times during ironing which is very annoying (for my wife). This was working before and we have tested here on different circuits already.
Sep 01, 2014 | Philips Gc8340/02 5 Bar Steam Generator,...
How do i stop water dripping onto my clothes
ensure that your iron temprature is high enough to generate steam. if ironing delicate cloth ensure your steam option is switched off. if your iron has a filler cap or water container ensure they are fitted securely. water dripping usually when the iron is too cold to turn it to steam or you have a leak somwhere.
May 21, 2014 | Irons
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
HI THERE, THE PROBLE WITH THE PHILIPS IRON GC7230 IS THE MOMENT ITS SWITCHED ON, ELECTRICITY TRIP. THANK YOU
The relay in the circuit board is probly fried together.Can be replaced but care should be taken and cord unplugged when working on the unit.
Aug 06, 2011 | Philips Irons
How do i descale it
Fill the tank with regular malt vinegar and leave it overnight, Was out in the morning and should have removed most of the scale. Then mix two parts vinegar and one part water and fill the tank again. Heat the iron up to max setting and steam through to remove any small deposits in the steam holes. Repeat if needed.
Feb 27, 2011 | Philips HI-296 Iron
Lost the details on how to clean Philips GC2540 iron. Please can you provide some information.
There are number of commercial cleaners available. CLR is one of them. You can also use 50% vinegar and 50% water.
Pour the mixture into the water chamber and let the iron sit overnight. Switch on the iron the next day and put it on steam. Hold the iron over the sink. The dirt will come out of the holes on the sole plate. If the iron is badly scaled you may need to repeat the process or use CLR following the instructions on the bottle.
Using distilled water in the iron will eliminate or reduce the need to de-scale the iron.
Nov 18, 2009 | Philips Irons
Phillips Azur Precice 4340 , lost instructions . How do you de calc it ? Thank you . Claire
Fill tank with water and put steam setting to 0.Set temp pial to hottest setting. Let the iron heat up till the light in the hand goes out. Switch off power and hold iron over sink. Push down and hold descale button until all the steam and water has gone from iron. Wipe plate and heat up iron again with no water in it.
Nov 09, 2009 | Philips HI-296 Iron
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Philips HI-296 Iron Logo
104 people viewed this question
Top Philips Irons Experts
ray gallant
Are you a Philips Iron Expert? Answer questions, earn points and help others
