Question about Acer Aspire 3680 Laptop
My acer screen is partially black
My acer laptop is partially black on the right hand side maybe about 20cm thick
  • DEKR
    DEKR May 11, 2010
    can you change screen settings by Fn and screen setting keys
  • Trevor Gordon May 11, 2010
    Sounds like the LCD is damaged. DId it get dropped or bumped?
  • 476 Answers
I beleive the chips in the screens outer edge have been damaged so only option is to replace lcd screen or use an external monitor
Posted on Feb 17, 2009
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
My acer aspire one netbook screen is black on right side, the left is in perfect view.
If the image is just too small for the screen then your video driver software is corrupt or no longer working. Re load the driver software.
If the image you see is only a partial image, then you have a screen driver problem and that is a problem. A new screen will be required.
Hope this helps.
Oct 22, 2010 | Acer Aspire One PC Notebook
1/3 screen display
Sounds like the inverter for the video has gone bad.
Jan 07, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Black screen on Acer 4720Z
If your booting to the splash screen ( ACER Logo screen ) then it goes black reboot - access the bios and do a bios hdd test - you mostlily find your hdd has died. Head scrash
Mar 07, 2009 | Acer Aspire 3690-2196 Notebook
Black screen on the right side of my acer 5630
You need to give me a few more details,is the screen blurry on one side,and brighter on the other?,two, are you using a some special graphics software that might not be ment for your computer,you should plug a monitor into your laptop to see if it gives the same affects,and press the window or function key, and one of the monitor symbols on your keyboard at the same time(,they are coloured the same as the function key),to change your main screen to a plug n play one,if the screen comes up with the same affects then it is a software problem,you might have to uninstall the software that is causing the problem,or two if is comes up perfectly,then it might be a hardware problem,you might have to bring your laptop to a pc mechanic to be degaussed,this puts a charge on your laptop screen and it costs more to do than replace one,most plug and play monitors can degauss them selves,others need to be done manually,unfortunately laptop screens have to be taken apart to be degaussed,i know its silly.if its not blurry then it cant be hardware problem.its one of your graphics settings.
Nov 25, 2008 | Acer Aspire 5630 Notebook
Partial blackout on Screen
I have the same laptop, and though I havent had a black out problem i do have screen burn or a discoloration in the lower corners of my screen. I was told that It was due to this model's overheating issue and that I would have to replace the screen.
Apr 20, 2008 | Toshiba Satellite M45-S331 Notebook
Partially dark screen
this sounds like a loose connection of your LCD back-light called the display inverter. squeezing, with your hand, the outer edge of the frame (NOT SCREEN) on the side affected could conform this.
Sep 22, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3680 Laptop Logo
314 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
