Question about Dell OptiPlex GX110 PC Desktop
Password problem i got a computer from a friend when you turn it on it says primary hard drive not found then below that it saystype the password enter to leave passwordenabled or press ctrl enter to disable password
  • jonie hull Aug 02, 2007
    got computer from a friend tried using boot cd for the password problem not working when i turn the computer on it wants a pass word to enable or disable security and it saYS PRIMARY HARD DRIVE NOT FOUND IF I TRY TO PUT IN PASSWORDS IT SAYS FAILED ATTEMPT AND THEN SAYS MUST SHUT DOWN
  • 3 Answers
If you don't care about the information on the hard drive, use a boot cd for your operating system (windows/linux/unix...whatever) to reformat the hard drive and then install it on the newly formated hard drive
Posted on Jul 28, 2007
SOURCE:
My dell inspiron 1546 says there is a primary hard drive password and a system password but why does it just shut down instead of letting me type a password?
Just answered a similar question. Did you set upthese passwords, or did some lame computer store geek do it? either way, you may have a BIOS sytem pass set up and need to know what that pass is. If repeatedly tap F2 or F10 when starting up it should take you to BIOS settings. If that is not the answer, and it windows password, you may have to image the hard drive in order to save documents on there and reinstall the drive. You can then view the image you saved (on another drive) to recover your docs.
Oct 13, 2015 | Dell Computers & Internet
Reset admin password dell inspiron b120
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b120-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
Apr 08, 2012 | Dell Inspiron B120 Notebook
Hard disk is protected by password
The hard drive needs the password. "Hard-disk #...., the system Primary HDD, is protected by a password authentication system. You cannot access data on this hard drive without the correct password."17 Jun 2008
Locked hard drive needs Dell password - Disk Drives (HDD, CD/DVD ...
en.community.dell.com/support-forums/disk-drives/f/3534/t/19063176..or try this link.... Hard disk is protected by password Google Search
Aug 29, 2011 | Dell OptiPlex 380 MT Desktop Computer...
My hard drive ask for a primary password when starting windows
Inorder to reset the BIOS password, you have to open the laptop from the back, locate the CMOS battery, remove it and press down the terminal (with the help of a screw driver) for 5 sec, now turn ON the computer (keep on holding the terminal) short the BIOS. Now, Turn off the computer and restart the computer, it will reset the BIOS password.
Thanks and regards,
Anil.B.R
Sep 24, 2010 | SmartDisk Computers & Internet
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Primary drive 1 not found
Try to use a different IDE cable. If that doesnt help, change your hard drive cable to the secondary IDE slot on the mainboard and change your BIOS accordingly, If still nothing try running two different drives wether its a hard drive, cd rom on one cable, or 2 hard drives doesnt matter just make sure that your jumpers are set properly.
Jan 09, 2010 | Dell Computers & Internet
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is [email protected]
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy ntdetect.com c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
Dell OptiPlex GX110 PC Desktop Logo
187 people viewed this question
Ekse
Clive
Clive
