hi, i bought a di-524 the other day aand i put the cd in but it fails at the existing router detected i did have other routers like netgear wrg-614 and microsoft mn-500also a linksys wrt-54g my modem does not have router capabilities help plzz im trying to install it so hopefully i get xboxlive.
Comments:
Aug 01, 2007
- but it fails the installation cd i cant install the di-524 yet and i dont have the old routers anymore?
Actually am using an ISP- BSNL and when Itry to connect to the ip address: 192.168.0.1, it's not getting connected and hence cannot make any chinages to the router settings, eventually can't connect to the internet. Can anyone suggest a solution for this problem?
I upgraded the firmware on my DI-524 and now there is no signal and I can't connect to the unit. My computer says 'host is down". All the IP setting on my laptop are fine and the unit worked before the firmware upgrade. The reset button doesn't do anything... I've tried to power it up with the reset in blah blah. Any clues how to get the unit alive agin?
Reset the DI-524 to its factory default settings and restore the other devices on your network to their default settings. You may do this by pressing the Reset button on the back of the unit. You will lose the current configuration settings. Also be sure to unplug the modem the plug it back in afterwards, a reboot of all devices on network maybe good idea also.
Was this helpful?
Yes
No
Solution #4
posted on May 11, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
What if the reset doesn't work!
Popular Solutions for D-Link AirPlus DI-524 Wireless
modem isn't not working, but all lamps are burning, i don't know what is the problem, can anyone...
(More)
modem isn't not working, but all lamps are burning, i don't know what is the problem, can anyone help me out this
how to setup up a access/bridge to connect 2 routers. I want to make a second router to receive a...
(More)
how to setup up a access/bridge to connect 2 routers. I want to make a second router to receive a dsl signal for my sonicview dongle
DI-524 Wireless Rourter D-Link To connect my laptop wireless I have to change the port. To use it on...
(More)
DI-524 Wireless Rourter D-Link To connect my laptop wireless I have to change the port. To use it on my desktop same thing. how do i correct that?
Using D-Link wireless router unencrypted and want to encrypt with the WPA protocol that it uses. The...
(More)
Using D-Link wireless router unencrypted and want to encrypt with the WPA protocol that it uses. The original installation CD no longer will work with my newer Vista OS. How can I get this thing encrypted?
Ihave xpdesk top computor not connected, and have a laptop vista connected to wireless router how...
(More)
Ihave xpdesk top computor not connected, and have a laptop vista connected to wireless router how can I connect desktop to wireless system
