Question about Compaq Armada M700 Notebook
Trouble booting up laptop
I have a Compaq Armada M700. Up until recently it worked perfectly, however recently it is not accepting power. If i fiddle with the adapter then it might accept power but for the most part i can't get it to turn on and stay on. Usually it will turn on and then turn itself off as if from lack of power. I'm not entirely sure what is wrong with it considering that if i fiddle with the adapter it will accept power. please help.
I do not think the battery is the problem. Do you leave the powerr adapter plugged in all the time? You should. Since you can make it work by moving the adapter plug, I suspect there is a lose connection in that area of the laptop or the adapter. As suggested above, try a different adapter first. You may email me for more information. [email protected]
Posted on Mar 01, 2008
  • 34 Answers
Possible that the battery is not holding charge. You might want to get a new battery, this happens from time to time with these models
Posted on Jul 28, 2007
  • 3 Answers
Goto a radioshack and ask if they can give you a replacement AC adapter for the computer. Bring the computer with you so that they can match it up. If the computer charges and works with the new adapter, it was the plug/adapter that you were using. If it still does not turn on, it may be a problem with the socket for the power adapter and you will need to have a certified repair technician take a look at it
SOURCE:
My Compaq M700 Armada , causing charging problem it run perfectly on direct supply from adapter but it do not charge battery. but was working perfectly few day ago....
hello,
Try removing battery and then re inserting. This can usually be done pretty simply by sliding lock to one side and the pulling battery out. This is under the laptop.
Hope this helps
Jan 08, 2011 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
The screem has broken and it can not power on
well you need to get a new LCD panel for your Armada M700. You could get something like this from eBay:
http://cgi.ebay.com/Compaq-Armada-M700-Laptop-For-Parts-or-Rebuild_W0QQitemZ360053106104QQihZ023QQcategoryZ177QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
(hurry....less than 8 hours left)
You could do this yourself if you are technically inclined.
May 23, 2008 | Compaq Armada M700 Notebook
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
Try to find a boot CD .Put that CD and try to start you computer and see it work or not.Incase it doesn't ,that mean you have a bad CDROM,you've to replace with the new one then.
takecare.
Apr 28, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq armada m700
might have to do a windows repiar with xp cd or formatt it all install fresh copy
Jan 26, 2008 | Compaq Armada M700 Notebook
Power
are you sure your get ac power, im thinking you ac plug in the computer is loose.
Dec 17, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
117 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
