Question about Dell Wireless Keyboard Optical Mouse w0147
Wireless mouse does not turn on
I have a wireless mouse. the led was low. i replaced the battery with new ones. it came on briefly .now it does not turn on at all.
  • ra4499 Feb 01, 2009
    No chief, its a microsoft-very expensive keyboard-mouse set. I opened the mouse and noticed some corrosive liquid from the aa cells had droppd on the ic near the LED. I cleaned it off with kerosene and use a pin to clear the corrosive buildup between the contacts. I then put in a pair of cells. The mouse came back to life after 2 days of putting in the cells and taking out as the leds would not respond to a surface as they usually do. now its fine.
  • b-edmonds Feb 05, 2009
    Same problem. Mouse was acting like it needed new batteries. Took out the existing and they had corrosion on them! Put in new batteries and now
    the mouse is not being read by the computer at all. Cursor won't move,
    can't do anything! HELP!
    Problem Solver:
  • 10 Answers
If it is a Logitech there is a reset button, and an on off button, check them out.
Posted on Jan 30, 2009
My mouse keeps turning off around 6 seconds after i turn it on, what do i do?
Need more information... What things have you tried? Have your replace the battery?
Sep 07, 2014 | iHome IH-M360C Mouse, Carbon
How to install verbatim blue wireless mouse
No Disk ? Go online to the company and they should have info. Or go to devices and have it search for new devices.
Jul 16, 2014 | Verbatim 97993 Wireless Multi-Trac Blue...
My wireless keyboard and mouse have never worked, but the lights are on for the mouse. Is there a way to turn the keyboard on?
first change the port of the USB receiver. then check the battery of the keyboar if it is good. other wireless keyboard has led indicator. other don't have so you have to check it manually.then check the mouse battery. if its weak replace it with new battery.
Aug 14, 2011 | Office Equipment & Supplies
How do I setup a wireless mouse on a desktop
To setup a wireless mouse regardless of its type, do the following:
1. Insert the USB transmitter (this could look like a mini plug or a stick) and wait for windows to complete installation.
2. Once this is successful, turn on the mouse by holding down the power button. Or insert the disc that came with the mouse and run the installer. The installer will install the device drivers and setup your mouse's configuration panel which will reside in your system tray.
Make sure that the mouse has batteries and that it is switched on for it to work. It will glow red when it is switched on.
Jul 06, 2011 | Gigabyte Wireless Optical USB Mouse GMW7C
Mouse died, replaced batteries, led lit then immediately goes out.
Make sure that the batteries you replaced are new. Dont ever use batteries that are used up together with a new one. Try and replaced again the batteries and see how it goes.
Good day.
Jun 19, 2011 | Dell Wireless Keyboard Optical Mouse w0147
NO LED ON MOUSE AFTER NUMEROUS CHANGES OF BATTERIES. ANY IDEAS?
After replacing the new battery with new one have you press connect button from the mouse side and the receiver side also. It is necessary to sync with the sensor the after replacing the battery
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Microsoft Wireless Mobile Mouse 3000
Spyder muse problem
Good batteries? maybe the signal in the mouse has died or been fried, or you could of had a wet hand when you used it and it could of messed up the laser or something, i dont know the solution but i tried to help
Jul 04, 2009 | AVENUES The SPYDER SwissGear Wireless...
Usb mouse not working on new laptop, was then all of sudden just quit
Is this a wireless mouse? If yes, you need to isolate the problem. Please follow the steps below:
1. Use fresh batteries.
2. Connect the wireless receiver/dongle into different USB ports of the computer.
3. Make sure that the mouse is turned on and then try to reconnect the mouse to the receiver by briefly pressing the connect button on the receiver and then hold down the connect button on the mouse.
Hope this helps and have a great day!
Jun 29, 2009 | Microsoft Wireless Notebook Optical Mouse...
Wireless mouse quits working after a few seconds
Did you replace the batteries? This sounds like it may be the problem. A year is a lomg time for batteries depending on how often you use the computer.
After changing the batteries, you may have to do this:
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Sep 03, 2006 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard Optical Mouse w0147 Logo
102 people viewed this question
Alun Cox
