Question about Canon DR-9080C Path-Through Scanner
Canon DR-9080C paper tray lift broken
I am sseking information or a valid site to retrieve the service manual for a Canon DR-9080c Scanner. It appears that the lift tray for the paper feed no longer functions. As I have not yet attempted to take it apart without a manual, I am under the assumption that either a gear/ belt /spring/ motor/ arm or something else is physically out of whack.
  • Anonymous Mar 04, 2009
    I just bought a used one and have the exact same problem.   Nothing happens at all - no error codes.  The lift tray doesn't move or seem to do anything.
  • cybernoypi May 19, 2009
    Hi - I have the same problem. I was wondering if S. Mohan was able to fix the problem.
  • 490 Answers
Michael, U can buy 9080C service manual at 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Posted on Feb 02, 2009
  • Mohan Sriraman
    Mohan Sriraman Feb 02, 2009
    My mail id is and you can contact me.
    S. Mohan
Set up disk for canon DR 9080 path through scanner
Hi Joseph, you should be able to find the driver for your OS on the Canon website here. imageFORMULA DR 9080C Color Production Scanner
Apr 10, 2014 | Canon DR-9080C Path-Through Scanner
Lower reading unit broken?
Ensure you have selected Duplex option. Canon DR 9080C uses LED lights and hence the chances of failure of light source is fairly low. Try scanning in Color.
The scan module, if required, can be replaced and is available in the market between $600 to $750. Please ensure that the module is faulty before replacing. (the upper and lower modules are interchangeable, except for a few plastic parts)S. Mohan, Chennai, India
Feb 24, 2012 | Canon DR-9080C Path-Through Scanner
Paper will not feed. the lift tray does work. 1.5 to 2 inches of the top of the paper feeds before it stops. when i used count only still get the same problem with
A01 is pickup error. Clean the paper sensor in the paper lifting tray and try. Clean the rubber rollers also.
Nov 17, 2011 | Canon DR-9080C Path-Through Scanner
Dr-9080c tray lifts up and down
IT could be a problem with the paper sensor. Please clean the sensor in the paper tray, it looks like a 'black dot' .
Nov 07, 2011 | Canon DR-9080C Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
My Canon Dr-9080C isnt pulling the paper into the scanner. The input try elevates, and then returns to it's original position, without the paper being pulled into the scanner, as if there wasn't any paper...
The scanner is assuming there is no paper. Just under the rubber rollers, in the paper tray there is a paper sensor. Clean that area with a damp cloth. Keep some papers and try "count-only". It it works then sensor is okay, else, you need to check the sensor.
S. Mohan, India
Jul 12, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner power supply
There should be cables connected to CN1 and CN6. CN3 is not shown on the circuit diagram in the service manual.
Apr 28, 2009 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
1,080 people viewed this question
old marine
old marine
