For the kettle's black 'charging' base:
Unplug this charging base immediately. Let it dry out completely. If you have an air hose, contact cleaner or Electronics Duster (compressed air) to displace the water.
If you're kettle stopped working after its fully dry (wait a day to be safe), make sure it's still unplugged and check the contacts in the base center for corrosion (there's the center ground pin and if you push down on it's spring-loaded ring around the ground pin you'll find two more inner/outer circumferential contacts). If you see corrosion try to clean them with a cotton swab (like Q-Tip) and alcohol and retry.
For the kettle's stainless steel 'pitcher' base:
It's the same as above but you'll need to expose the bottom for best results and to find out where's this water it leaking from.
You'll need to remove the 3 Phillips screws and one safety-screw with a "spanner insert bit" on your driver. If you don't have access to one of those and your kettle leaks when filled then I'd bet it's cheaper to replace than to repair, sorry.
