Question about Panasonic Lumix DMC-LZ7 Digital Camera
I have lumix dmc-lz7. Tonight I put a 2 gig sd card into my built in card reader , Dell pc and it didn't work and did not even show the drive on computer. Then, to check it out, I connected camera to usb port and it then worked with the reader and showed the drive on the comp. Why doesnt card work alone in reader?
  • horses5009 Feb 25, 2009
    Thank you for your help but I think it may be the card itself as my daughter's sd card worked in my comp fine. I think I will look it over once more and then buy the same card that my daughter uses. My Dell is 12 in 1 or 21 in 1 reader and has an sd/mini MMC/RS slot as well as several other slots so it should work???
Maybe the card reader is not SD/SD HC compatible, the same problem occurs wiith the Memory Stick Pro/Duo of sizes 2GB or above in my Desktop Computer (Compaq) and not in my Notebook (Compaq) the card reader and the machine are newest and are compatible
Posted on Feb 25, 2009
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
My Panasonic DMC-LZ7 is not not recognized by computer when usb cable plugged in. It has always worked before and not is not.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 17, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a DMC-LZ7, with some pictures on the built in memory. Can I transfer those pictures to a memory card? The pc cable doesn't talk to the camera.
Yes. There's a "Copy" option in the playback menu. It can copy all pictures from internal memory to a card, or individual pictures from a card to internal memory.
Sep 28, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I don't know how to get photos from my DMC-LZ7 camera to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Jul 28, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I have a panasonic lumix DMC-LZ7 and never had this problem before but when i hooked the camera up to my computer to import the photos it always said connecting with an arrow on a wavy line and now it says...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
May 14, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
I have recently aquired my Lumix TZ7. I took a
When you say it did not work with the card reader, are you saying nothing appeared on your computer? No icon on your desktop, no Windows box offering ways to open your pics, and finally, did you open "my computer" to see if they appeared as a "removable disc"?
Feb 01, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Transfering pictures
I have a DMC-LZ7 that I purchased a year and a half ago. You can transfer pics from the built-in memory from the "copy" menu function when the camera is in play mode (10th option down in the menu). If you move the cursor down to this selection then hit the right arrow button, there should be options to both transfer from built-in memory to the SD card and vice versa.
Sep 19, 2008 | Panasonic Lumix DMC-FS5 Digital Camera
Camera as a gift
Do you have a SD card reader? you could get the memory card out of the camera, and put the card in your cardreader.
you could also just use the usb cable, i suppose you have windows xp or vista, it should install automatically.
the software is for old versions of windows, and other os's.
mark
Dec 13, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic Lumix DMC-LZ7 Digital Camera Logo
85 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
