Question about Nintendo GameCube Console
How do I connect game cube to an old tv
I have an old RCA tv. It Doesn' t have the three input holes (red, white, yellow).
It just has the one for cable.
ALso If I can find out how to connect it somehow I still don't know where to find the input select, AUX, Line In, or whatever.
I was hooking it up through the VCR, which we got rid of and now I can't get it to hooked up directly to the TV.
  • slms34 Jan 30, 2009
    I figured I might need a medium to connect it through But I do'nt know what to get.
  • Anonymous Jan 31, 2009
    im problem fixer
  • 45 Answers
Its not actually possible to connect it to your tv if it doesnt have a rca or a scart socket. if you have the old cables for a nintendo 64 they might work on it but otherwise you will need a new tv or medium to connect it through. If you did manage to connect it then you wouldnt need to play it on AV as because it was going through the aerial it would just appear on one of the channels.
Posted on Jan 30, 2009
  • Daryll Clarke
    Daryll Clarke Jan 30, 2009
    Maplin do so many cables they are bound to have what you want if you discribe your problem to them
Hooking atari flashback to the tv/
White is sound yellow is picture.
look for three rca jacks red white yellow. connect and set tv to see whatever input you connected to. white can go either white or red but yellow must match.
Dec 24, 2013 | Atari Flashback 2 Console
You're not very clear about why you cannot get the GameCube to play, but if I may assume, it sounds as though your TV does not have the necessary input to get the game cube plugged into it.
If this is correct, you can find an RF Adapter which will work on Any TV with a coaxial (cable) input. If your TV doesn't have the red, yellow, white inputs, this will work for your gamecube and your TV:
Jun 16, 2011 | Nintendo GameCube Console
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
What type of cable do i need to connect a dsr-30 to a TV?
Use the RCA video cable have Yellow,Red,White.Just plug the three Y,R,W,connetion plugs in the out holes input in the VCR.The other side of the cable Y,R,W,connection plugs to the other end Y,R,W to the tv in holes out input.
Mar 26, 2010 | Sony DSR-30 Mini DV VCR
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
55-57 High Street
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
I have a older Sony TV. I want to connect my magnavox dvd and older surround sound and my DISH network together. I need a diagram or step-by-step instructions as I am NOT literate to hooking these...
I will ilustrate how you do this .. first your magnavox dvd has a cord,has three defferent color of RCA jack yellow ,red and white,yellow is for video,red is for the rigth speaker and white for the left speaker. the video or yellow cord is input to the TV in the VIDEO 1 section the red and white cord is input to your old surround sound, next is your DISH network the output cord is going to input to the VIDEO 2 section in TV.. the video cord color yellow and the red and white to the is going to input in old surround sound, and the out of your old surround is for the speakers...if happens that your sound is one input by a Y RCA jack ,Y jack HAVE ONE INPUT and two output,,,feel free for asking question for further assistance in the future rate me a fixya.....
Jun 19, 2008 | Audio Players & Recorders
Nintendo GameCube Console Logo
339 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
