Question about Frigidaire FGF316 Gas Kitchen Range
Gas ignitors do not shut off
The gas ignitors do not turn off on all burners. We have to unplug it to stop which leaves the top burners unsafe. What is causing this problem and how can we fix it?? Thanks for your help! Randy Osborne
  • 5,911 Answers
Are you saying the spark module is constantly sparking? If so, you may have one of your surface burner switches shorted, causing the spark module to stay on. Or, you could have a ground in your wiring harness to the spark module. Here's a way to check: 1. Unplug range, or turn off circuit breaker. 2. Locate your spark module. It's usually located in the back of the oven cavity, or behind the rear panel. There should be a wire going from the spark module to each burner switch. Carefully disconnect each burner switch one at a time and re-energize your range to see if the problem goes away. If the problem doesn't go away, turn the range back off, reconnect the switch and move to the next switch wire. 3. If you disconnect each switch and the problem persists, then I would suspect an internal short in the spark module, or a ground in your wiring somewhere. There should be a tech sheet with diagrams located somewhere on the back of the range to assist you. I hope this helps.
Posted on Jul 28, 2007
SOURCE:
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Ignitors won't stop sparking
heatman101
Apr 30, 2010 | Avanti DG-20CW-1 Gas Kitchen Range
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
All of the burners on my range started flikering at the same time and they were off. I could not stop them. I saw a little smoke escaping from the rear right burner. It finally stopped flickering and now...
yikes .. you have a very dangerous condition there ... ventalate the area and turn the gas off immediatly.. there is a shutoff valve somewhere in the gas line coming to the stove top .. if you cant find that then shut off the gas at the gas meter or call the gas company to do that for you (its free) ...
your problem is likely a loose pipe or cracked manafold .. it is leaking gas under the cooktop .. i would replumb the unit and check for cracks .. or call a professional .. your unit comes with a 1 year warranty or an additional 4 years if you bought extra coverage .. that probably wont cover a bad installation if thats the problem (unless the repair company installed the unit to start with) .. but will cover the stoves inside plumbing ..
your stove is not safe the way it is .. if you can still smell gas then you shouldnt be in the house until the gas is turned off ... windows should be open .. dont turn on lights or other things that can ignite the gas .. and absolutely dont try to relight the burners until the problem is fixed ..
Nov 12, 2009 | Maytag MGC5536 Gas Cooktop
The electrodes are ticking when we turn on the burners
THAT IS THE IGNITOR FOR THE GAS. TURN THE KNOB JUST BEYOND THE START POSITION AND IT SHOULD STOP. IF NOT UNPLUG THE STOVE AND FIND THE IGNITOR ON THE BURNER HEAD AND CLEAN IT WITH A SOFT TOOTHBRUSH. PLUG THE STOVE IN AND IT SHOULD STOP CLICKING
Aug 22, 2009 | GE JGP975SEKSS Stainless Steel Gas Cooktop
Dryer blowing cold air
UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. You can try and replace the ignitor without removing the burner. Sometimes it is just as easy to remove the burner. Make sure the gas is shut off before removing the gas fitting on the gas valve. Be carefull and DO NOT touch the black part of the ignitor with your hand. It could ruin the ignitor with the oil on you hand.
If I can assist you further, please let me know.
Thanks
Vic
Jul 05, 2009 | Whirlpool LGR5636L Gas Dryer
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Frigidaire FGF316 Gas Kitchen Range Logo
271 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
