Question about Esky Honey Bee King 2 RC Helicopter
Lama v3 spins counter clockwise with no lift off
Crashed heli bought extreme body kit now no lift off adjusted 4in1 replaced moters checked gears blades goinig in rite direction i dont know what the deal is ive tried everything ,the first v3 i bought did this out of the box so i use it for parts and bought anouther one it flies great but since i crashed it and put it back together it wont lift has same problem this must be common please any ideas
WOW! I have experienced the same spinning action . . all new parts etc. I have repaired 6 Coco's but this one has ate my lunch . . . when you power up it spins to the left . . . the more throttle the faster it spins . . have changed the 4 and 1 also and adjusted . . . over and over . . . does the 4 in 1 control the rudder action?
Posted on Feb 14, 2009
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
It spins until it crashes.
adjust the trim, turn the knob the oppside direction the nose of the heli is spinning, if that dont work then either your weight is wronge or you have trash in your gears
Apr 30, 2011 | Air Hogs Reflex Micro Helicopter
counter clockwise would be the nose tuning to the left. My sons did this and pressing the right trim button on the controler repeatedly untill it slows is all I had to do. If you go to far it will spin int the oposite direction then you have to trim to the left and find the happy middle
Dec 26, 2010 | Toys
Crashed hard and now the bottom rotor is not spinning as fast as the other two. What should I do?
loosen the body screws. lift the right side front so you can see the engine gears, The little gear has slipped on the shaft and is not making contact with the big gear (white plastic gears). Slide the little gear down the shaft so it meshes with the bigger gear. Close the body back up (don't tighten screws yet). Turn the Heli on and make sure all is well (while holding the body closed). Tighten screws...Enjoy...
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
Walkera lama 400 just spins round
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Sep 12, 2010 | Walkera Toys
Bee King 2 spins in anti-clockwise direction.
Go to to get solutions to all your heli problems and questions.
Mar 25, 2009 | Esky Honey Bee King 2 RC Helicopter
I bought my sons Walker Lama 2 Copters and we need
Is the lower shaft blade not rotating.. and making flimsy noise....and olnly the upper rotor blades rotate and it does not fly even at full throttle...
If above is the problem, then check the corresponding motor gear, if you could see, white shades over the black, plastic body, then the chances of that gear, might have been worn out.. if it is the same, then replace the gear, it should work......
Mar 20, 2009 | Walkera HM5#10 RC Helicopter
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Lama v3. going in circles
looking from the above top roters should rotate anticlockwise bottom roters should rotate clockwise also check blades are fitted right way round. I only sugest this because you have replaced the 4 in 1 and could have put on connections wrong wa round easy mistake good luck
Nov 12, 2008 | Esky Honey Bee King 2 RC Helicopter
Esky Honey Bee King 2 RC Helicopter Logo
716 people viewed this question
Top Esky Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Esky Toy Expert? Answer questions, earn points and help others
