Remote's functions dont control the air con anymore.
I have a Fujitsu Air conditioner model AST30RGB-W.
It was fine when i was using it the other night and using the remote i turned it off. The next night i tried touse it but it wont turn on. It seems pressing the remote to turn it doesn't work anymore. An air con guy came to do repairs at my work and he told me toturn off the mains then turn it on again and see how that went (which was a tip i didn't try). The 2nd suggestion was to hit the reset button inside the air con's panel. My air con is about a 5-6yrmodel and i couldn't find any reset button but i saw it had a manual/autoturn on and turn off button. It turned on when i pressed it and thetried to change the settings with the remote but it didn't work therefore I'mguessing its the sensor on either the remote or the air conditioner that isn't functioning. Maybe its something else, i really don't know... but withoutgetting a techie how would i be able to find outif it is and which of the sensorsis playing up... the remote sensor or the air con's sensor?
Thanks for any feedback which woud be greatly appreciated.
Kind regards,
Michael.
  • vudoo11 Feb 02, 2009
    yeah, that's the 1st thing i checked... then i changed to a brand new set of batteries but still no go.
    Thanks all the same, lenwest.
  • 150 Answers
Have you checked the battery's in your remote?
Posted on Jan 30, 2009
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
Digitech ar 1731 Air conditioner remote. I need code for Fujitsu AC Model AST12LSBCW please
Fujitsu Air Con codes for the Digitech AR1731 Universal Remote Control for Air Conditioners are:-
1152
0464
0127-0137
Dec 12, 2013 | Televison & Video
Remote control functioning unit is functioning, but remote control is not activating unit, could you please help. Part number is 9365005019.fujitsu room split air coditioner
Hi Russell Webe, just a guess, but sounds as though the remote receiver board is faulty, however you might try new batteries in the remote first,it may help. failing that it is time to call the serviceman. Also try turning the power off to the Ac unit for about 5 minutes and then back on again. This will reset the electronics and again may solve your problem regards. col www.digitalcontrols.com.au
Feb 23, 2011 | Fujitsu 24R1 Air Conditioner
After I changed the battery of the remote the AC will not respond. I have to turn on the AC manually. T
dear sir
please turn off the switch of air con and after two minut turn on, your main electric soures for reset the settings then it will show to you on it,s display Green light. it is sign of power supply after that you can use your remote control with your air con,
hope answer the question
thank you
please vote!
Sep 25, 2010 | Fujitsu 24C1 Air Conditioner
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Fujitsu Reverse air con not blowing heat anymore
Reverse setting could need checking here sliding valve could have siezed. you would need a service Technition. your default setting is working fine so it needs to be checked on heating mode function.
Jun 09, 2009 | Heating & Cooling
Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Jan 23, 2009 | Fujitsu 24C1 Air Conditioner
My fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Jan 07, 2009 | Fujitsu 36CS Air Conditioner
Heating & Cooling Logo
594 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
