Question about Sony KP-51HW40 51" Rear Projection Television
Image completely distorted
I have had a KP-51HW40 TV for about 5 years. Couple weeks ago, the image shown on the screen suddenly becomes out of shape. All three colors are out of alignment and the image is bended like a picture been squeeze from top to bottom in the middle. According to some articles on the net, it is possible due to the broken convergence ICs (STK392-560) which I replaced. However, the problem is still there. It would be greatly appreciated if you could offer some help.
  • 398 Answers
In that set there is a fuse for each of the 6 channels in the convergence circuits and there are also 2 fuses on the power supply board which feed the * and - supplies to the convergence IC's. If one of the fuses opens on the power supply board then the new convergence IC's will not work and your colors will not line up and the edges will bow in. The fuses are labeled on the board with "F---" and look like small yellow resistors. If you properly replaced both convergence IC's, examine all 8 fuses and replace the open ones and your convergence will return to normal.
Posted on Jul 30, 2007
    President:
  • 3,130 Answers
You will need the service manual to locate the blown resistors and or the circuit protectors in this TV set. If you know how to read the service manual, the schematic, and trace the circuit, know how to use and ohm meter and a volt meter, I am sure we can fix this set together. Let me know with an e-mail address so I can save you 30 bucks for the service manual. Good Luck
Posted on Jul 29, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Jul 29, 2007
    Oh , also make sure you double check, no triple check your soldering work on the IC's you replaced, as I have seen many times small solder bridges across the connections cause many problems too.
  • Larry  Dillon
    Larry Dillon Jul 30, 2007
    Manuals on its way. Good Luck
  • Larry  Dillon
    Are you sure of the e-mail address, as the mail came back as undeliverable
SOURCE:
Aproximately 50% of the Tv's image is distorted by a green and red doubled image. Can we fix this
Yes, this problem can be fixed if you are handy with electronics stuff repair and can solder parts in circuit board easily with proper tools.
Replace convergence out ICs to get converge picture.
Let me know exact model number and brand of your TV for further info as question shows its Sony KP-51HW40 tv.
Jan 08, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS510
you need a green CRT thats whay you have the white kind of concave lines with the green screen. You can try adjusting the green screen control but you need anew CRT ( tube) the speaker cover has two plastic plugs that get removed on the lower edge os the grille which covers the two screws that hold the grille on. If you need more assistancr or where to get a green CRT let me know as I have a link that has some green and red Tubes for your model.
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Green cicular lines appear
Bad green CRT = try turning down green screen control
behind front access panel...................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Image is totally distorted
Did you also replace the bias resistors required when you converted from STK392-110 to the higher STK392-xxx modules? If I wer you I would go back to the orginal modules only new ones. Then I would also get a schematic to test the voltage levels on the chips to make sure they are the same as on the schematic.
Jul 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40
I read it online that this is a very simple problem. It needs highvoltage splitter. I tried to open the front panel to see where the splitter is. However, I need some hint as to how to open the front panel. Good luck. Kiran
Feb 19, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
