Question about Compaq Armada 100S Notebook
Touchpad mouse not working on laptop, only 3 months old
Whenever i touche dit testerday it made a hideous noise. then it stopped working. also the keypad doesnt work sometimes, so i have to reboot. it is a spanish machine so idont alwayas understand what it is telling me, it suggested i uninstall adobe flash player, sies that make sense? the usb mouse works fine.
My husqvarna designer 1 keypad doesnt work
It could be the Touch Screen. If it is a Designer 1. If it is a Designer II or Quilt Designer or #1 it could be the Dcard. Recommend it be checked by an Authorized Viking Dealer. You can find the nearest dealer from the Viking website - http://www.husqvarnaviking.com/us Click on the link Locate a Dealer.
May 21, 2014 | Husqvarna Sewing Machines
Samsung corby pro full key pad not working only touch pad working
there must be fault in keypad.contact your device dealer and change the keypad of your problem.this will fix your problem
Dec 27, 2010 | Samsung B5310 Cell Phone
Hi my nokia 3110c...phone whenever...i switch the phone on...the keypad doesnt work..infact it just works a few seconds as the phone is loading..(enough time to unlock the keypad using the security code)...
Hi, when a keypad does not work on a phone, it is usually caused by dirt inside the keypad area of the phone,you can open the phone and clean up the keypad area.
Sometimes too, as the case may be Chips also can affect the keypad and allows the phone keypad not to function.
There is an IC chip inside that controls the function of the keypad.
You can fixed the IC chip inside the phone by replacing the damaged IC inside the phone.
When you replace the damaged IC .i assure soluton tothe problem.
Take care.
Oct 07, 2010 | Nokia 3110 Cellular Phone
The touch screen of my samsung GT-S5230 phone is not
my gt-s5230 touch screen stop working. how can i reset it?
Feb 13, 2010 | Samsung Star GT-S5233 Cell Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Noise from computer
It could very well be the noisy fan. Try tapping the computer lightly to see if the noise stops or changes to confirm if it indeed is the fan. Or it could be a noisy HDD.  There is nothing you can do about a noisy HDD but about a noisy fan you can stop worrying as it will cause no probs as long as it is working, noisily or otherwise. You will have to tolerate it. Sometimes it is the detatchable sides of the computer (you wrote 'computer' in your question). See if the noise stops or lessens when you touch the sides a little harder.
May 09, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My phone's touchscreen is not working.
Touch screen for me rarely goes not working, but it wl be normal after sometime or after i restart the phone. You can try do flashing. Goto motorolafans.com and know how to flash your E6 and try it. If stil;l the problem doesnt rectify, You have to goto motorola service center.
Jul 18, 2008 | Motorola Mobility ROKR E6 Smartphone
Compaq Armada 100S Notebook Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
