Question about HP Photosmart 3180 All-In-One Printer
Connecting scanner to computer
I want to be able to scan a page onto my computer so I have it digitally
  • 88 Answers
I had the same problem with my HPc6280, go to www.hp.com/support and go to chat with them and they were very helpful for me.
Posted on Feb 23, 2009
Put photos on facebook? Not from phones, or cameras with simscards, just old photos.
Scan them onto your computer, save them to your computer. Go to your facebook page, hit upload photo, go to browse button, go to where you stored your pics ie. photos or desktop, find the pic you want to upload then click on it, hit ok and it should upload for you.
Jan 22, 2015 | Cameras
I need to see the scan counter
Hi Dwayne,
You can view the scanner counter as follows:
For Windows XP:
1. Turn the scanner on connected to your PC. Open My Computer, right click on the displayed scanner model
2. Click Properties, under the "Device set", you can see the total page count.
For Windows 7:
1. Turn the scanner on connected to your PC. From the "Start" menu, click on "Devices and Printers"
2. The scanner model is appered in the window.Right click on the displayed scanner model
3. Click 'Scan Properties', under the "Device set" tab, you can see the total page count.
Thanks & regards,
ScanCare
Nov 30, 2011 | Fujitsu ScanPartner 15C Flatbed Scanner
How do i scan documents onto my comp
It depends a bit on the software you have installed (OS, etc). If you installed the full-featured software before connecting the all-in-one to your computer, you can scan immediately from the computer. For Windows, open the HP Solution Center (by double-clicking on the icon or Start > All Programs > HP folder > HP Solution Center). Put your document to be scanned face down on the scanner glass and close the lid (ADF pages go face up, top edge first). Click the tab in the Solution Center for your HP product (if you have more than one) and click Scan Picture or Scan Document as appropriate. Set the scanner settings in the pop-up window if needed. Click Scan to start the scan. To use the buttons on the scanner, you need to set the destinations for the buttons in the HP Solution Center (Scan to destination for example) and have the HP monitor running on your computer (this listens to the buttons).
Scanners work with bi-directional communication so USB hubs, print servers or bad cables can result in the printer functions working but not the scanner.
If you install the generic OS driver (by connecting the all in one to the computer before installing the software), the printer will work but the scanner will functions will be limited (the scanner buttons will not work but other functions will depend on the OS). Windows XP can acquire scans in Paint (File > From Camera or Scanner). Windows Vista and Win7 add Windows Fax and Scan which will also acquire scans (not in all versions of Vista). Vista also can acquire scans with Windows Photo Gallery.
The printer works similarly with the Mac OS but hte names may be different.
I hope this helps.
Jun 14, 2010 | HP DeskJet F4280 All In One Printer InkJet
I try to scan a document and it says that I am not set up on pc. I use just the scan button and it still won't scan. Help please!!!
Verify cables connected properly to the back of the scanner
If the scanner is a parallel port scanner it is likely it has two available connections on the back of the scanner. Verify that the cable coming from the computer is connecting to the IN, Computer IN, computer, or similar connection.
Ensure that the scanner is getting power
If your scanner is not getting power it is recommended that you check the connections ensuring that they are connected properly to the back of the computer and from the scanner to the wall. If you have the scanner connected to a power strip and or surge protector it is temporarily recommended that you connect the scanner directly to the wall.
If the computer scanner is getting power, you should notice the inside light come on when the power is first received by the scanner.
After checking the connections you still get no power to the scanner, it is recommended you contact the manufacturer of the scanner.
Additional parallel port scanner troubleshooting
If you have another device connected in between the scanner and the computer, turn off the computer and temporally disconnect the devices connected to or from the scanner. If, after disconnecting these devices, the scanner works, it is likely that another device may have issues or may be unable to work with other parallel devices.
PC Windows users verify no TSRs are running in the background
Press CTRL + ALT + DEL and end task all currently running software except explorer and systray and attempt to scan again. If this resolves your issue it's a possibility that an application in the background such as a virus utility is preventing your scanner from scanning.
Verify the LPT port mode
PC users ensure that the LPT port mode within the computer BIOS is set to either EPP or bi-directional mode and/or try alternating between these two modes.
Update the drivers
Verify that the latest drivers are installed for the operating system being used on your computer. A listing of computer scanner manufacturers and links to the drivers pages can be found on our scanner drivers page.
Nov 19, 2009 | HP LaserJet 3055 All-In-One Printer
Lexmark X2600 how do i scan a document onto my computer
put the page face down on the scanner and on the software click the scan button and once it scans save it as a .pdf or whatever format you want
Oct 30, 2009 | HP PSC 1210v All-In-One InkJet Printer
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
How to Scan a Picture onto the Computer
turn the printer on, place the picture on the glass, on the printer under mode press the big silver button until the scan light comes on  then press select, you should hear the picture scanning, then on the computer, go under my pictures and you should see that picture.
Apr 16, 2009 | Lexmark P4350 All-In-One InkJet Printer
Pasting typed written material onto Microsoftword.
won't scan slides . . . light in lid will not come on
what do i do? Epson Perfection 4180 Photo Scanner
Jan 17, 2009 | Compaq S 200 Flatbed Scanner
Morning, I need to scan a hard copy page on to my computer...not sure of the steps? I put page under the lid and hit scan button...
Normally, You can scan from scanner or your computer. Either way, you will have to save it onto your computer. If you hit the scan button, it should pull up the scan software for you, with options and preferences for you to choose from. If this is just for records/storage purposes, just choose the default settings and save it under a name and location you will remember. Hit scan and you should be good to go...
Dec 05, 2008 | Office Equipment & Supplies
HP c4280 All in one printer, scanner, copier.
I visited the HP Support site and downloaded the Uninstaller and then the Installer. It took about 90 minutes but has cured the problem completely. I also made sure all drivers were up to date from the HP site check.
Apr 11, 2008 | HP Digital Printers - Hewlett-Packard...
HP Photosmart 3180 All-In-One Printer Logo
Ben Johnson
