Question about Koutech Systems Koutech KW-2103MS Memory Stick USB Card Reader/Writer, Retail (dsktkw2103ms)
Memory stick duo reads full but it is not really that full
My memory stick duo reads its full but when i computed the total megabytes of my games there is still a large space and when i try downloading more games in it, it said that it is already full. Is there something wrong with it?? i hope somebody can help... Thanks
    President:
  • 2,559 Answers
There is a reserved amount of unused space that is required for files used to run it.
Think of it this way,A blank disk will show nothing.Add a one word document and write protect the disk,It will show the disk is full,Even though you know it only has one word written to it.
Please rate this a fixya
Posted on Jan 30, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Memory stick pro duo reading problem
Usually that means there is a problem with the memory stick itself. Try replacing or buying a new memory stick
May 09, 2010 | Sony PlayStation Portable (PSP) Console
My 8 gb memory stick duo is full and now it cannot be read by any psp or computer. Help me please.
make sure it's not in lock mode. if youre still having problems, you may need to reformat the stick.
Mar 09, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
My psp can put miusic
You need a memory stick duo to play music on your PSP, when you insert the MS duo into the PSP, make sure you got the settings menu and format the MS duo. that way, when you plug the PSP into the PC, it willl already have the neccesary folders to put your music in
Aug 03, 2009 | Sony PSP (Piano Black)
Sony Memory Stick PRO Duo Not reading
Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
Feb 13, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have a memory Stick PRO Duo 4GB
YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
PROBLEM WITH THE 8GB SANDISK MEMORY STICK DUO
Place PBP files in the GAME folder and ISO/CSO games in the ISO folder of the Memory Stick root. You might have to make this folder yourself.
Jan 06, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory stick pro duo pc connection
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
  1. Open System in Control Panel.
  2. On the Advanced tab, under Performance, click Settings.
  3. On the Advanced tab, under Virtual memory, click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in the Initial size (MB) or Maximum size (MB) box, and then click Set. If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note:
  • To open System, click Start, point to Settings, click Control Panel, and then double-click System.
  • To have Windows choose the best paging file size, click System managed size.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of Ram on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory
  • To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
Feb 10, 2008 | Computers & Internet
Koutech Systems Koutech KW-2103MS Memory Stick USB Card Reader/Writer, Retail (dsktkw2103ms) Logo
153 people viewed this question
Top Koutech Systems Televison & Video Experts
Are you a Koutech Systems Televison and Video Expert? Answer questions, earn points and help others
