Question about HP DeskJet 710c InkJet Printer
Ink cartridge removal problem
I wanted to change the cartridge of my HP 710C printer but the Cartridge Loader wouldn't go to the CENTER after I opened the Top Cover of the Printer. What seems to be the problem with it?
  • 150 Answers
Try unpugging the printer and wait 15 seconds to clear the memory before turning it back on.
Posted on Jan 30, 2009
I will change ink cartridge but the problem is. I do not know to eject. My printer is HP Deskjet Ink Advantage 2060 all-in one k110. Please help me. Thank you.
Replace the cartridges
To replace the cartridges
1. Check power. Make sure printer is on
2. Load paper.
3. Remove cartridge.
a. Open cartridge door. Wait for print carriage to move to center.
b. Press down to release cartridge, then remove it from slot.
May 30, 2011 | HP Office Equipment & Supplies
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
How to chang ink
When it is time to replace an ink cartridge in your HP inkjet printer, you will receive a pop up message on your computer screen. Replacing an ink cartridge is just part of owning an inkjet printer, and a tradeoff with the high quality imaging you are able to achieve on an HP inkjet. It is not something a professional needs to do; just follow these simple instructions to complete the change and get right back to printing.
  1. Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
  2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
  3. Press the change cartridge button. It is at the top of the printer next to the power button.
  4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
  5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
  6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
  7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Good luck.
Apr 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
How to install the ink
Step 1 Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low. Step 2 Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step 3 Press the change cartridge button. It is at the top of the printer next to the power button. Step 4 Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step 5 Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step 6 Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step 7 Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Want to know more then please go through this HP Website link - Click Here
Anand Kumar Fixya
Apr 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
HP Deskjet 710c
either the cartridge ink is dried up or near to empty.or the printer settings are selected in colour and made black printing off.
Dec 10, 2008 | HP DeskJet 710c InkJet Printer
How to remove ink cartridge for hp 4150 printer?
Hi there
step #0
Step #12Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step #23Press the change cartridge button. It is at the top of the printer next to the power button. Step #34Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step#45#4Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step #56Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step #67Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door. thanks Hamedo
Nov 22, 2008 | Office Equipment & Supplies
HP DeskJet 710c InkJet Printer Logo
113 people viewed this question
Ben Johnson
