Question about Acer X193W LCD Monitor
Windows xp not shutting down what should i do?
  • 150 Answers
Try unpluging your power supply then take out the battery,wait 10 seconds,then put the battery back and plug in the powersupply.
Posted on Jan 30, 2009
Turn power on stays on few mintues then shuts down turn power off and back on does same thing screen looks a little dim
what kind of computer do you have what kind of os or operating system windows xp,200, vista just to name a few
Feb 15, 2014 | KDS Computers & Internet
Monitor goes into power saving mode while working with xp operating system
Probably not a problem with the monitor but rather the power settings for windows. right click on the desktop and go down to properties select the screensaver tab and click the power settings button. Under here you can change the settings for when the monitor shuts down. Personally I would select never.
Aug 17, 2011 | IBM ThinkVision L190 19" LCD Monitor
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
Monitor goes on and off........seemed to come on for the xp boot, but then disappears or is intermittant when the xp login page appears. Only fix sometimes is to reboot the computer. Very strange. Only...
In your Windows XP
  1. Go to Start and click
  2. The Start menu will open
  3. In the start menu click settings
  4. In the settings select "Control Panel"
  5. The Window of control Panel click "Power Options"
  6. In the Power options you will find Display time settings. These are the time settings that determine the time like if your computer stay idle for 5 min, the display will shut down.
  7. I suspect that this time is set to be very low like if there is no activity on the computer such as key punching, typically happens when you are reading an e-book Windows will automatically shut down the display. So you can increase the idle time to say 7-10 minutes and/or a similar setting is "Put the computer to sleep". Try to carefully alter the time values and you will find a good settings that work for you.
If the above tip does not work then there is definitely something wrong with your monitor's hardware most probably the power supply. You need to check it with a repair shop.
Good Luck!
Dec 09, 2010 | Xerox XG-71D 17" Flat Panel LCD Monitor
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
15" Dell monitor
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
Apr 18, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Acer X193W LCD Monitor Logo
26 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
