Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Upgrade Possible? Hello I have just bought a Playstation 3 and my tv does not support 720p but it supports 1080i and 480p when it plays a game that supports only 720p it downs it to 480 insted of 1080i can i upgrade my tv to support 720p i have a RCAD52W20 HDTV Monitor
    Champion:
  • 317 Answers
You will need to contact RCA helpline for the procedure
Posted on Oct 19, 2007
SOURCE:
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
When my ps3 is on 720p or 1080i there is this white fuzzy line that oulines certain images on the tv such a faces and clouds and such.. but when its on 480p its fine.. i bought a new HDMI cable thinking it...
This happens when using hdmi for me, free to air digital tv is fine, but playing games has the exact same problems as you describe, and even dvd's etc do it, but not very noticeable at all, needs to be slow paced with a high contrast in in the picture usually.
May 29, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont go 1080i/720p
I don't think there is a way to set your resolution manually, bro. They do it all by auto. If I may make a suggestion... Turn off both the TV & PS3. Unplug your HDMI, then make sure both your TV & PS3 are turned ON. Now re-connect your HDMI. A TV tech once told me that these units "communicate" through the HDMI. This can only occure whilst they're up & running. This may help get you going on to 1080i.
p.s. PS3 games only output 720p, max! This isn't always the case for Blu Ray movies, but it is for games. Good luck!
May 23, 2009 | Sony PlayStation® 3 (60 GB) Console
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
1080p 480p
if you hold down the power button when you turn it on for more than 4 seconds it runs the display setings and puts it in the best possible option
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Pink HDTV screen PS3
check that you have all avalubal resulutions sulected in your displt settings i.e. 480p 720p 1080i and 1080p all the ones your tv will support my ps3 was doing the same thing untell i checked 480p as well as 720p and 1080i now when I play a dvd my tv swiches to 480p and the dvd will play.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Call of Duty 4 Modern Warfare
It is 1080p, but your tv must be compatible with 1080p your tv more than likely only supports 720p. My tv only supports up to 1080i and that is what I play in
Dec 06, 2007 | Sony Playstation 3 (PS3) Console
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
140 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
